Author Topic: insert blocks  (Read 4066 times)
Humbertogo
insert blocks
« on: January 18, 2008, 01:47:36 PM »
How to insert blocks using vb.net 2005
and what is the best way to preview dwg
Humbertogo
Re: insert blocks fatal error
« Reply #1 on: January 18, 2008, 04:52:38 PM »
afther close acad get fatal error i using this function to insertblocks
what is wrong with this  function?
    Public Function InsertApiBlock()
        Dim insertionPoint(2) As Double
        Dim Comp As String
        Comp = "d:\temp\test.dwg"
        insertionPoint(0) = 10 : insertionPoint(1) = 20 : insertionPoint(2) = 0
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim ed As Editor = doc.Editor
        Dim tr As Transaction = doc.TransactionManager.StartTransaction
        Try
            Dim dwgName As String = HostApplicationServices.Current.FindFile( _
                                    Comp, Application.DocumentManager.MdiActiveDocument.Database, FindFileHint.Default)
            Dim db As Database = New Database(False, False)
            db.ReadDwgFile(dwgName, IO.FileShare.Read, True, "")
            Dim BlkId As ObjectId
            BlkId = doc.Database.Insert(dwgName, db, False)
            MessageBox.Show(Comp)
            Dim bt As BlockTable = tr.GetObject(doc.Database.BlockTableId, OpenMode.ForRead, True)
            Dim btr As BlockTableRecord = tr.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite, True)
            Dim bref As BlockReference = New BlockReference(New Autodesk.AutoCAD.Geometry.Point3d(insertionPoint), BlkId)
            btr.AppendEntity(bref)
            tr.AddNewlyCreatedDBObject(bref, True)
            bref.ExplodeToOwnerSpace()
            bref.Erase()
            tr.Commit()
        Catch ex As System.Exception
            ed.WriteMessage(ex.ToString)
        End Try
    End Function
Fatty
Re: insert blocks
« Reply #2 on: January 18, 2008, 05:25:04 PM »
As I see in ObjectARX SDK docs this method should work
just with uniform scaled blocks
Thus, you don't defined scale factors, it would not work for you
Try this instead:
#Region " AcadDlls"
Imports System
Imports System.IO
Imports System.Collections
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.DatabaseServices
Imports graph = Autodesk.AutoCAD.GraphicsInterface
Imports Autodesk.AutoCAD.ApplicationServices
Imports AcDb = Autodesk.AutoCAD.DatabaseServices
Imports AcApp = Autodesk.AutoCAD.ApplicationServices.Application
Imports AcGe = Autodesk.AutoCAD.Geometry
Imports AcRx = Autodesk.AutoCAD.Runtime
#End Region
Module Module5
    Sub main()
        InsertApiBlock()
    Public Sub InsertApiBlock()
        Dim Comp As String
        Try
            Dim scl As Scale3d = New Scale3d(1, 1, 1)
            bref.ScaleFactors = scl
            bref.UpgradeOpen()
            bref.Erase()
            tr.Commit()
        End Try
End Module
Humbertogo
Re: insert blocks
« Reply #3 on: January 18, 2008, 06:27:34 PM »
still have fatal error
MickD
Re: insert blocks
« Reply #4 on: January 18, 2008, 07:10:34 PM »
Can you debug to find where it's failing?
Even some temp prompts/user interaction placed at points in your code to display notes at the command line to find where you are getting up to in your code before it crashes would help.
- John Carmack
- J.R.R. Tolkien
It's Alive!
  • Retired
  • AKA Daniel
Re: insert blocks
« Reply #5 on: January 18, 2008, 10:41:42 PM »
try adding this after tr.Commit()
   db.CloseInput(true);
   db.Dispose();
Re: insert blocks
« Reply #6 on: January 19, 2008, 12:56:52 AM »
   db.Dispose();
or wrap the transaction with a using statement or 2
Humbertogo
Re: insert blocks
« Reply #7 on: January 19, 2008, 01:45:26 AM »
okay thanks it work fine
            ''bref.ExplodeToOwnerSpace()
            ''bref.Erase()
why is Block Name: ""
witch method need to use to defined scale factors
« Last Edit: January 19, 2008, 02:05:47 AM by Humbertogo »
Fatty
Re: insert blocks
« Reply #8 on: January 19, 2008, 04:34:08 AM »
            ''bref.Erase()
I have a got the same result
I don't know why this happens, I need to play with
this moment extensively
Pephaps, instead of this method better yet
to use just Explode method but I'm not sure
about, sorry
~'J'~
