We are using 2008 MEP and for some reason the express tools cannot be loaded from the disk....during the load process nothing ever comes up about the tools.
Quote from: TJAM51 on January 25, 2008, 10:38:19 AMWe are using 2008 MEP and for some reason the express tools cannot be loaded from the disk....during the load process nothing ever comes up about the tools.http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=5543312&linkID=9240937
Note: If you still want to install Express Tools with either Autodesk Architectural Desktop or Autodesk Building Systems, you can select the Custom installation type during the initial installation and enable the Express Tools option.If you have already installed Autodesk Architectural Desktop or Autodesk Building Systems without Express Tools, and you now want to install Express Tools, you can use the Change option in the Windows Add or Remove Programs dialog box. You can then access the Add or Remove Features option, which can be used to Add Express Tools to an existing installation.
