Author Topic: Freezing layers in a current viewport  (Read 5065 times)
Columbia
« on: August 06, 2004, 09:29:47 AM »
Alright people,
I need to be beat over the head a little because for some reason I can't get this little test program to work.  I'm trying to add a layer to a paperspace viewport entity list so that it becomes frozen in the current viewport only.
The layer "CENTERLINE" exists in the drawing already.
Any help with this code would be most appreciated...
(defun c:test (/ ename layer elist)
  (setq ename (car (entsel "\nPick ViewPort..."))
        layer (vlax-vla-object->ename
                (vla-item
                  (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
                  "CENTERLINE"
         elist (entget ename)
         elist (append elist (list (cons 331 layer)))
  (entmod elist)
  (entupd ename)
« Reply #1 on: August 06, 2004, 09:39:15 AM »
Im not really sure i understand what your trying to do exaclty, but if you try using "vla-add" instead of "vla-item" would that do what you want?
« Reply #2 on: August 06, 2004, 09:42:32 AM »
...nevermind, i think i see what your trying to do.
« Reply #3 on: August 06, 2004, 09:46:15 AM »
Heres a snip from the help docs
Restrictions on Using entmod
There are restrictions on the changes the entmod function can make:
An entity's type and handle cannot be changed. If you want to do this, use  entdel to delete the entity, then make a new entity with the command or entmake functions.
   The entmod function cannot change internal fields such as the entity name in the –2 group of a seqend entity—attempts to change such fields are ignored.
   You cannot use the entmod function to modify a viewport entity.
***DARNIT! (I hit the button to fast)
Did that help?
Columbia
« Reply #4 on: August 06, 2004, 09:52:28 AM »
Yeah, that explains why the snippet doesn't work.  But that leads me to the next question...
How the HE$$ are you supposed to freeze layers in the current viewport if there is no other method other than the (command) call??
« Reply #5 on: August 06, 2004, 10:05:07 AM »
<guess>Have you tried vla-setxdata and vla-update on the viewport object?</guess>
Columbia
« Reply #6 on: August 06, 2004, 10:50:54 AM »
No, I haven't.  But only because I don't think the layer names/handles/IDs were attached as XDATA.
If they are what APP are they listed under?
Columbia
« Reply #8 on: August 06, 2004, 12:05:30 PM »
A little...
I guess the short answer to this is:
You have to use (command "._vplayer") to do what I want it to do.  There is no other method available to the VLISP world.  :cry:
Thanks guys for showing me the futility in what I was trying to do.   Maybe I'll go find a tall bridge, and leave my parachute at home...
daron
« Reply #9 on: August 06, 2004, 01:15:58 PM »
It's funny that this:
70 Standard flags (bit-coded values):
1 = Layer is frozen; otherwise layer is thawed
2 = Layer is frozen by default in new viewports
4 = Layer is locked
16 = If set, table entry is externally dependent on an xref
32 = If this bit and bit 16 are both set, the externally dependent xref has been successfully resolved
64 = If set, the table entry was referenced by at least one entity in the drawing the last time the drawing was edited. (This flag is for the benefit of AutoCAD commands. It can be ignored by most programs that read DXF files and need not be set by programs that write DXF files)
doesn't say anything about what you are after. I see that bit code 2 talks about new viewports, but nothing about the state of a layer frozen in a viewport. That or I'm just not seeing it. I've just learned how limiting layer states can be too. They seem to have the same limitation. They work in modelspace and if the new vp freeze is active or not, but don't work in paperspace otherwise, if at all.
