This is one of those things where version is important...
Are you using 2008? This line no longer should have a special layer in 2008... If you need to change the display of all of them, easiest way is to pick one, then right-click and do "Select Similar", then change whatever you want to change in the Properties window.
But 2007 was quite different...
