So how do you get the *.bak files to save to a certain directory when using a qsave? Currently, it saves them to the same path as the drawing. I would like to isolate them to one directory rather that having them scattered all over the network.
Thanks,
Ron
Make sure you've thought this through before you do this. It can work if you have strict naming conventions for your files that result in no two drawings having the same name, regardless of the directory or project they may be in, but it can still cause problems, especially in multi-user environments...
Most of the time, if you're trying to get to the .bak file, having it right there with the original drawing is the most convenient place for it. Just configure your automated-backup software (you have some, right?
![Cheesy :D](http://www.theswamp.org/Smileys/black/cheesy.gif)
) to ignore the .bak files, and make sure they're deleted before you archive a project.
