Author Topic: Entlast using the doc.Editor  (Read 3725 times)
« on: November 30, 2007, 10:54:07 PM »
I was reading through the ObjectBrowser, ( as one does on a Saturday morning),
and this caught my eye.
public PromptSelectionResult SelectLast();
Declaring Type: Autodesk.AutoCAD.EditorInput.Editor
so I had a play.
The core of this could probably be wrapped and used as an alternative to P/Invokeing acdbEntLast().
This is pretty basic, but may be handy ..
sorry, no piccy ; you'll need to build it to see :-)
// CodeHimBelongaKwb ©  Nov 2007
using System;
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
[assembly: CommandClass(typeof(SelectLastTest.TestCommands))]
namespace SelectLastTest
    public class TestCommands
        [CommandMethod("SelectLast")]
        static public void testSelectLast()
            Document doc = AcadApp.DocumentManager.MdiActiveDocument;
            PromptSelectionResult whatsLast = doc.Editor.SelectLast();
            if (whatsLast.Value != null
              && whatsLast.Value.Count == 1)
                AcadApp.ShowAlertDialog("\nEntlast ObjectID is: "
                                        + whatsLast.Value[0].ObjectId);
            else
                AcadApp.ShowAlertDialog("\nOooops Nothing to see ");
Re: Entlast using the doc.Editor
« Reply #1 on: December 01, 2007, 01:10:29 AM »
Perhaps something like this is worth a try ..
added:  or would returning an Entity or DBObject be better suited ?
        /// <summary>
        /// Return the ObjectID of the last entity in the DataBase
        /// </summary>
        /// <param name="db"></param>
        /// <returns></returns>
        static public ObjectId SelectLastEnt(Document doc)
            PromptSelectionResult LastEnt = doc.Editor.SelectLast();
            if (LastEnt.Value != null && LastEnt.Value.Count == 1)
                 return  LastEnt.Value[0].ObjectId;
            return ObjectId.Null;
        [CommandMethod("TestIt")]
        static public void testSelectLastEnt()
            // bla, bla
            ObjectId LastDBEntID = SelectLastEnt(doc);
            if (LastDBEntID.IsNull)
                // oops
                return;
                                        + LastDBEntID);
« Last Edit: December 01, 2007, 01:26:36 AM by Kerry Brown »
« Reply #2 on: December 01, 2007, 01:57:34 AM »
.. though this seems to work ..
using System;
using DdTMan = Autodesk.AutoCAD.DatabaseServices.TransactionManager;
        /// <summary>
        /// </summary>
            Database db = doc.Database;
            // bla, bla
                // oops
                return;
            DdTMan tm = db.TransactionManager;
            DBObject LastDBObject;
            using (Transaction tr = tm.StartTransaction())
               LastDBObject = tm.GetObject(LastDBEntID, OpenMode.ForRead, true);
                                        + LastDBEntID
                                     + "\nEntlast Type is: "
                                        + LastDBObject
edit/added: a picky for joe.
« Reply #3 on: December 01, 2007, 08:25:53 PM »
public static ObjectId EntLast();
Declaring Type: Autodesk.AutoCAD.Internal.Utils
Assembly: acmgdinternal, Version=17.2.0.0
public static extern unsafe int modopt(CallConvCdecl) acdbEntLast(int modopt(IsLong)* modopt(IsConst) modopt(IsConst));
Declaring Type: <Module>
[**have patience grasshopper]
