Author Topic: Visibility  (Read 5149 times)
Luke
Visibility
« on: November 28, 2007, 12:30:19 PM »
When I click on the arrow to select a different visibility of a dynamic block the oprions do onot show up.  But when I go to my neighbors PC and do the same thing the block works properly.  Any idea how to get the visibility choices to show up?  Parhaps for some reason a setting is toggled off on my machine?  Full version Vanilla 06
Guest
Re: Visibility
« Reply #1 on: November 28, 2007, 12:47:04 PM »
Got an old version of the block?
Have you tried the RESETBLOCK command?
Luke
Re: Visibility
« Reply #2 on: November 28, 2007, 01:06:20 PM »
I'm just testing the blocks that come as part of the software install.  I've also tried creating my own new blocks.  I have now also tried RESETBLOCK and none of them work.  But whenI go to my neighbors machine they do.  I do not have an old version of the block.
Guest
Re: Visibility
« Reply #3 on: November 28, 2007, 01:57:52 PM »
Can you change the visibility state from the Properties palette (when you have the DB selected of course)?
Guest
Re: Visibility
« Reply #4 on: November 28, 2007, 02:01:11 PM »
Luke
Re: Visibility
« Reply #5 on: November 28, 2007, 02:18:42 PM »
Yes I'm able to toggle through in the Properties manager.
The right click customization also got it.
Thanks!
Guest
Re: Visibility
« Reply #6 on: November 28, 2007, 02:28:47 PM »
Thanks!
You're welcome.  Glad you got it working again.
