Hey Guys,
I also wanted to toss this in
Just to clarify; my initial intent was to insert the raster at -8 in the X direction so that it was off the title block for the users to pick their points. I originally used the move method for that but I changed it. Instead, I it at -8,0,0
Then you can fill in the move section when/if you know where the raster will permanently reside
Sub InstRastMkCBnd()
Dim RastImg As AcadRasterImage
Dim Imgpath as String, Imgname as String
Dim InsertPnt(0 To 2) As Double, Scalefactor As Double, RotAngle As Double
Imgpth = ThisDrawing.Path & "\" 'assumes Image File is in the same directory as your drawing
Imgname = "Filename.ext"
ThisDrawing.ActiveSpace = acPaperSpace
InsertPnt(0) = -8#: InsertPnt(1) = 0#: InsertPnt(2) = 0#
scalefactor = 1
RotAngle = 0
'On Error GoTo Errorhandler
Set RastImg = ThisDrawing.PaperSpace.AddRaster(Imgpth & Imgname, InsertPnt, Scalefactor, RotAngle)
RastImg.Name = Left(Imgname, Len(Imgname) - 4)
RastImg.scalefactor = 12
'Move Points
Dim MPointN(0 To 2) As Double 'Negative
Dim MPointP(0 To 2) As Double 'Positive
MPointN(0) = 0: MPointN(1) = 0: MPointN(2) = 0
MPointP(0) = 0: MPointP(1) = 0: MPointP(2) = 0
'Move Raster
RastImg.Move MPointN, MPointP
