Author Topic: xref color change  (Read 2763 times)
dussla
xref color change
« on: November 07, 2007, 08:43:11 PM »
i made xref object
as i selected xref object , i would like to change xref all layers color
1.all xrefs color -> bylayer
2.all xrefs color -> bylock
3.all layers clolor in 1xref object -> bylayer
4.all layers clolor in 1xref object -> byblock
5.1 layer color in 1 xref object -> bylayer
6.1 layer color in 1 xref object -> byblock
possbile is these ?
i will wait your good answer ~~~
thank you
and good day~
daron
Re: xref color change
« Reply #1 on: November 08, 2007, 08:40:13 AM »
Not sure how good the answer could be. Numbers, 1 and two are pointless and I mean that as I see it, doing that wouldn't produce any results. 3-6, you determine that in the original drawing. 1-6, you can't have both at the same time. That, or I don't understand what you're looking for.
Joe Burke
« Reply #2 on: November 08, 2007, 10:07:00 AM »
See my reply in the Autodesk customization NG.
I detest these cross-posts!
« Reply #3 on: November 08, 2007, 10:41:03 AM »
Whoa dude, off the meds again?
CADaver
« Reply #4 on: November 08, 2007, 05:29:19 PM »
hmmm... considering that many of us no longer troll the Autodesk groups, I'm not sure this would be considered a cross-post.  I for one would be interested in your solution, but not so much as to drag through the Adesk forum for it.
daron
« Reply #5 on: November 08, 2007, 05:39:07 PM »
As would I, considering I still haven't made sense of what it is that is being asked for.
« Reply #6 on: November 17, 2007, 09:22:14 PM »
Flaming is not required, but a link would be nice.
cross posting only happens when the posting site(s) are not independent ... thus if one posts at Autodesk NG and theswamp, it is not considered cross posting ... because they are INDEPENDENT of one another.
Imagine if there were only 1 web site allowed to have a post on a particular subject. Search engines would only show 1 relevant web page .. because other pages would be disallowed under your obvious definition of cross posting.
I would suggest that if you find duplicate questions by a single author in various forums that are independent of one another, you should either provide a link to the site providing the most accurate answer or simply ignore the post.
