Author Topic: Writing Layers to a text file  (Read 6031 times)
ML
Re: Writing Layers to a text file
« Reply #15 on: October 12, 2007, 11:12:00 AM »
Yeah, that is a cool idea CM and I have done something similar in other cases but I guess I never described what I am using it for.
My boss wrote a LISP routine that will grab the layers from the supporting text files (which I am creating with this code)
create a filter in a user's drawing based on those layers, then grab the drawing prefix (dwgprefix) for the project path and use the text file name & ".dwg" to create the nec. AutoCAD (xref) drawing.
We are a very xref friendly company here so this will make it much easier for the user to create the nec. xrefs for their project relativily quickly.
Having said that; I am simply writing some supporting code.
Now, if a person (CAD User) on the floor, or the company overall needs to add a layer(s) for future xrefs, then can just add or delete it from our master dwg xref files, then run this code to regenerate the new text file.
"If someone would like to help me further develop this, I need the layer count minus defpoints and 0 then write that as the first line in the text file, then after that will follow the layernames minus 0 and defpoints.
That would be really cool if someone wants to take my exisiting code and expound on it.
Thank you
ML
« Reply #16 on: October 12, 2007, 11:13:28 AM »
Note:
After the filter is created in the drawing, it will obviously be wblocked out but that is all done in The LISP routine, I am just focusing on the text file part
David Hall
  • Automatic Duh Generator
« Reply #17 on: October 12, 2007, 01:55:11 PM »
Post your code and I will see what I can add
ML
« Reply #18 on: October 12, 2007, 01:59:15 PM »
I did CM but here it is again
This will likely require more VBScripting
I appreciate it.
I will also look at it again later if I get time
Thank you very much,
Sub WriteLayersToATextFile()
Dim FSO, MyFile As Variant
Dim Layr As AcadLayer
Dim Dwgname As String
Set FSO = CreateObject("Scripting.FileSystemObject")
Dwgname = UCase(Left$(ThisDrawing.GetVariable("Dwgname"), Len(ThisDrawing.GetVariable("Dwgname")) - 4))
Set MyFile = FSO.CreateTextFile("C:\Path\Path\Path\" & Dwgname & ".TXT", True)
For Each Layr In ThisDrawing.Layers
 MyFile.WriteLine Layr.Name
Next Layr
MyFile.Close
End Sub
David Hall
« Reply #19 on: October 12, 2007, 02:28:40 PM »
try this, It puts in the layer cuont at top and bottom.  They should match if defpoints exists, or be off by one if not
Option Explicit
      Dim intLayerCount As Integer
      Set MyFile = FSO.CreateTextFile("C:\" & Dwgname & ".TXT", True)
      intLayerCount = ThisDrawing.Layers.Count - 2
      MyFile.writeline intLayerCount
      intLayerCount = 0
            If Not Layr.Name = "0" Then
            If Not Layr.Name = "Defpoints" Then
                  MyFile.writeline Layr.Name
                  intLayerCount = intLayerCount + 1
            End If
            End If
      Next Layr
      MyFile.Close
End Sub
« Last Edit: October 12, 2007, 02:31:53 PM by CmdrDuh »
ML
« Reply #20 on: October 12, 2007, 02:53:48 PM »
CM
I have not tried the code yet and I am about to
However, I think with the way that VBScript and The Text Stream methods work, I may need to write it
MyFile.writeline intLayerCount & MyFile.writeline Layr.Name
But let's see how it handles it
Thank you for the code
I will try it now
David Hall
« Reply #21 on: October 12, 2007, 03:12:30 PM »
I didn't put any error checking for the layer Defpoints, thats why the layer numbers were there.  You could also use the layer number piece to number your layers
Myfile.writeline intlayercount & vbtab and layer.name to number them.
ML
« Reply #22 on: October 12, 2007, 03:22:57 PM »
Yes that is cool but I can't for this one because The LISP routine reads the top number for the layer count
Then the layers.
ML
« Reply #23 on: October 12, 2007, 03:35:23 PM »
CM
Thanks again; I really appreciate it
I tweaked it a bit and it seems to be working fine:
I also added in the username method, so it will write the file directly to your desktop if you want to test it
Sub WriteLayersToATextFile2()
Dim FSO, MyFile, Username As Variant
Set WshNetwork = CreateObject("WScript.Network")
Username = WshNetwork.Username
Dwgname = UCase(Left$(ThisDrawing.GetVariable("Dwgname"), Len(ThisDrawing.GetVariable("Dwgname")) - 8))
Set MyFile = FSO.CreateTextFile("C:\Documents and Settings\" & Username & "\Desktop\" & Dwgname & ".TXT", True)
  End If
 End If
Next Layr
MyFile.Close
End Sub
I still need to see what will happen if I defpoints does not exist in a drawing
ML
« Reply #24 on: October 12, 2007, 03:36:49 PM »
Oh by the way
The code I just posted is dropping 8 characters off the end of the drawing name; I have to try something differet.
You may want to change that back to 4
David Hall
« Reply #25 on: October 12, 2007, 04:44:07 PM »
I took your idea and started writing a Standards Checker that checks fonts, layers, layers for certain blks, etc. I'll post if anybody is interested
ML
« Reply #26 on: October 12, 2007, 05:34:58 PM »
What idea was that CM?
Of course I would be interested but ACAD has a built in Standards checker (CAD Standards Toolbar)
David Hall
« Reply #27 on: October 12, 2007, 05:40:03 PM »
I couldn't figure out how to get all my standards into the checker, so I started writing my own
Option Explicit
Public Sub GetInfoLayers()
      Dim objLayer As AcadLayer, objFont As AcadTextStyle
      Dim strDwgName As String
      Dim strLayername As String, strLayerLinetype As String, strLayerColor As String
            ThisDrawing.PurgeAll
      strDwgName = UCase(Left$(ThisDrawing.GetVariable("Dwgname"), Len(ThisDrawing.GetVariable("Dwgname")) - 4))
      Set MyFile = FSO.CreateTextFile("C:\" & strDwgName & ".TXT", True)
      MyFile.WriteLine "Drawing: " & strDwgName & ", located at: " & ThisDrawing.Path & "\"
CheckLayers:
      MyFile.WriteLine " "
      MyFile.WriteLine "Non Standard Layers: "
      For Each objLayer In ThisDrawing.Layers
            strLayername = objLayer.Name
            strLayerLinetype = objLayer.Linetype
            strLayerColor = objLayer.color
            If CheckName(strLayername) = 1 Then
                  MyFile.WriteLine strLayername & vbTab & strLayerLinetype & vbTab & strLayerColor
            End If
      Next objLayer
CheckFonts:
      MyFile.WriteLine "Non Standard Fonts:"
      For Each objFont In ThisDrawing.TextStyles
            Select Case UCase(objFont.fontFile)
            Case "ROMANS.SHX"
            Case "VERDANA.TTF"
            Case Else
                  MyFile.WriteLine objFont.Name
            End Select
      Next objFont
CheckTitleBlocks:
CheckImages:
      Dim objRasterImage As AcadRasterImage
'      For Each objRasterImage In ThisDrawing.ModelSpace
'            If Not objRasterImage.Layer = "ANNO-SCAN" Then
'                  MyFile.WriteLine "Image: " & objRasterImage.Name & " wrong layer, on layer " & objRasterImage.Layer
'            End If
'      Next
      MyFile.Close
End Sub
Private Function CheckName(LayerName As String) As Integer
      Dim FSO, MyLayerFile As Variant
      '      Set FSO = CreateObject("Scripting.FileSystemObject")
      '      'Set MyLayerFile = FSO.OpenTextFile("c:\layer.txt", ForReading, False, TristateFalse)
      Open "c:\layer.txt" For Input As #1      ' txt file is list of good layers to check against
      While Not EOF(1)
            Line Input #1, strLayername
            If LayerName = strLayername Then
                  Close #1
                  GoTo Good
            End If
      Wend
      Close #1
      CheckName = 1
      Exit Function
Good:
      CheckName = 0
      Exit Function
End Function
This is how far I have gotten so far today, NO ERROR checking, so use at your own risk
David Hall
« Reply #28 on: October 12, 2007, 05:42:03 PM »
Im purging 3 times b/c I haven't checked if this method will purge nested entities completly.
Also, the layer checker , I couldn't figure out how to use the FSO object and EOF so I reverted back to VBA Open for Input
David Hall
« Reply #29 on: October 12, 2007, 05:43:47 PM »
I also need to add to the font checker to put the text style as well as font file
