Author Topic: Writing Layers to a text file  (Read 6147 times)
ML
« on: October 11, 2007, 06:51:08 PM »
Hi
I am trying to write out my layers from a drawing to a text file.
As far as creating the text file, that part is working fine; it is grabbing the drawing name and creating a text file however
I can not get the layers to write to the file.
My guess is because layers are an object and not a string, even though the layer names are a string..... hummm?????
If I replace the line MyFile.WriteLine ThisDrawing.Layers line with something like MyFile.WriteLine "Hello", it works just fine.
Does anyone know how I can get this to work?
Thank you,
Sub WriteLayersToATextFile()
Dim FSO, MyFile As Variant
Dim Layr As AcadLayer
Dim Dwgname As String
Set FSO = CreateObject("Scripting.FileSystemObject")
Dwgname = UCase(Left$(ThisDrawing.GetVariable("Dwgname"), Len(ThisDrawing.GetVariable("Dwgname")) - 8))
For Each Layr In ThisDrawing.Layers
 Set MyFile = FSO.CreateTextFile("I:\Path\Path\Path\Path\" & Dwgname & ".TXT", True)
Next Layr
End Sub
Glenn R
  • What idiot child of married cousins wrote this?!
Re: Writing Layers to a text file
« Reply #1 on: October 11, 2007, 06:54:38 PM »
That's because you're trying to write out to the file the entire layer collection in one hit.
Change this:
to this:
MyFile.WriteLine Layr.Name
Me
Glenn R
« Reply #2 on: October 11, 2007, 06:56:16 PM »
Also move your CreateTextFile line OUTSIDE of the for loop - before it in fact, otherwise you will be creating a textfile for each layer in the drawing.
Also don't forget to close the textfile when finished.
Me
ML
« Reply #3 on: October 11, 2007, 07:09:57 PM »
Dam Glenn
Without even trying it, I know you nailed it!
Of course layer.name DUH
Also, you are correct, if I keep the writetextfile in the loop, I would get a .txt file for each layer
I will move it out
Thank you very much!
ML
« Reply #4 on: October 11, 2007, 07:34:40 PM »
Actually,
This may seem like a dumb question but I can do
Set layrs = Thisdrawing.layers
However, if I pull the layr variable out of the loop, then it needs me to set a reference to layr
and I can only use the name method on individual layers
So, how would I set a reference to the layr variable so that each layer in the layer collection can be read, then written?
I tried something like this, but no luck
Set layr = Thisdrawing.layers.item (0)
Thanks again,
Glenn R
« Reply #5 on: October 11, 2007, 07:41:46 PM »
I don't follow you. Your code posted looks about right, but here is a quick example:
Public Sub SpewLayers()
    Dim pLayers As AcadLayers
    Dim pLayer As AcadLayer
    Set pLayers = ThisDrawing.Layers
    For Each pLayer In pLayers
        ThisDrawing.Utility.Prompt "Layer name: " & pLayer.Name & vbCrLf
    Next
End Sub
Me
ML
« Reply #6 on: October 11, 2007, 10:58:39 PM »
Hey Glenn
OK, I figured it out and you were partially right.
Absolutely, I had to use the layer.name method to get the layer name
However, the layr.name code must remain in the loop for AutoCAD to grab the name of each layer in the layer collection.
As far as The Writeline method; it will do precisely that; it will write a line for each in layer in the layer collection
Also, as you add layers, you can re run the macro and it will overwrite the existing file with the new layers.
So, here is the working code:
Thank you for the help!
Dim Layrs As AcadLayers
Set Layrs = ThisDrawing.Layers
Dwgname = UCase(Left$(ThisDrawing.GetVariable("Dwgname"), Len(ThisDrawing.GetVariable("Dwgname")) - 4))
Set MyFile = FSO.CreateTextFile("C:\Path\Path\Path\" & Dwgname & ".TXT", True)
Next Layr
MyFile.Close
End Sub
« Reply #7 on: October 11, 2007, 11:30:00 PM »
Hey Glenn
Mark, I read that Glenn said move the File creation, not the file WriteLine.
.. I can't see where he suggested relocating the MyFile.WriteLine Layr.Name
kdub in one timeline.
--> Donate to theSwamp<-
Glenn R
« Reply #8 on: October 11, 2007, 11:32:11 PM »
Of course...I never said to remove it from the loop.
Me
Glenn R
« Reply #9 on: October 11, 2007, 11:33:47 PM »
No, my answer was exactly right for the question asked.
Kerry, you beat me to it.
Me
ML
« Reply #10 on: October 12, 2007, 10:01:41 AM »
From your second post:
OK, you're right, you said move the CreateTextFile line outside of the loop.
My fault.
You were right......feel better? :)
Thank you again
ML
« Reply #11 on: October 12, 2007, 10:04:24 AM »
I was very tired yesterday.
Sorry guys....
I looked at it last night and it then hit me.
It goes to show that sometimes you do need to walk away from it
Well, anyway, may be someone else will benefit from the final result "posted"
Thank you again
M-dub
« Reply #12 on: October 12, 2007, 10:04:32 AM »
Just a quick note, you might find something helpful here -> http://www.theswamp.org/index.php?topic=1341.15
ML
« Reply #13 on: October 12, 2007, 10:09:00 AM »
Cool
Thanks M-
David Hall
  • Automatic Duh Generator
« Reply #14 on: October 12, 2007, 10:21:18 AM »
Why not add Layer.Color and Layer.Linetype and make it tab delimited, then you can pull it into Excel?
