Author Topic: An ObjectIdList Class  (Read 3848 times)
« on: October 01, 2007, 07:30:13 AM »
Thought this might be useful, based off of Tony’s TypedValueList class.
public class ObjectIdList : List<ObjectId>
    public ObjectIdList()
    public ObjectIdList(ObjectId src)
      base.Add(src);
    public ObjectIdList(ObjectId[] src)
      base.AddRange(src);
    public ObjectIdList(ObjectIdList src)
      base.AddRange(src);
    public ObjectIdList(ObjectIdCollection src)
      foreach (ObjectId oid in src)
        base.Add(oid);
    public static implicit operator ObjectIdList(ObjectId[] src)
      return ((src != null) ? new ObjectIdList(src) : null);
    public static implicit operator ObjectIdList(ObjectIdCollection src)
    public static implicit operator ObjectId[](ObjectIdList src)
      return ((src != null) ? src.ToArray() : null);
    public static implicit operator ObjectIdCollection(ObjectIdList src)
      return ((src != null) ? new ObjectIdCollection(src.ToArray()) : null);
« Last Edit: October 02, 2007, 09:09:45 AM by Daniel »
Glenn R
Re: An ObjectIdList Class
« Reply #1 on: October 01, 2007, 08:31:57 PM »
Hi Daniel,
Nicely done, however, I'm failing to see the use/benefit of this...can you elude as to your thoughts for creating this and possible usage scenarios? Also, how about explicit conversions as well?
LE
« Reply #2 on: October 01, 2007, 10:26:56 PM »
Daniel;
Is that Alfonso Arau in your avatar?
« Reply #3 on: October 02, 2007, 01:01:11 AM »
Hi Daniel,
It’s only to add a little flexibility to the collection by being able to use the built-in member methods of List. I.e. AddRange(),  Foreach(delegate or lambda expressions)  etc.
I didn’t have a need for explicit operators, but I am sure that could be added. I posted it to show that this technique could be used on other collections where the additional flexibility might convenient i.e, searching, sorting, the future use of in memory LinQ queries etc.
Dan
« Reply #4 on: October 02, 2007, 01:05:52 AM »
Daniel;
Yes sir it is, AKA "El Guapo" from The Three Amigos.  :lol:
But I am El Guapo too. We are both El Guapo  8-)
« Reply #5 on: October 02, 2007, 04:51:19 AM »
polymorphism in action ?
Glenn R
« Reply #6 on: October 02, 2007, 08:41:20 AM »
roflmao Kerry!
