drawing schematics we hatch the stuff that is to be removed, but the hatching can't be over the text. So the way of doing this has been;
1) hatch everything
2) draw a few rectanges
3) go through each one with trim select rectangle then select the hatch on the inside of each rectangle
i can't use the the drawing to find the where to put the rectangles as i'm usually hatching over a raster image.
any good ideas to get rid of a step or two, or make it easier (good way to not have to select the inside of each rectangle?)
edit forgot to add, i jump in at step #2... because after #1 "it takes too long for me (some engineer) to do"
