Author Topic: List_box Multiple_select  (Read 9552 times)
V-Man
« on: July 16, 2004, 09:27:55 AM »
I'm working on this lisp and I'm a little stumped. This lisp works with a
dialog box (list_box)(with multiple_select option) to select 1 or more
than 1 item in the list and then pass the findings to a variable and eventually
start the (mtext) command, Ask the user mtext starting point and place
in mtext the findings from the selected list_box values.
Can someone aid me with this prob.
Thanks,
This is from Kenny's. Thanks.
(defun C:Test ()
(setq NAMES '("01Monday" "02Tuesday" "Wednesday" "Thursday""Friday" "Saturday" "Sunday"))
(setq dcl_id (load_dialog "popup.dcl"))
(if (not (new_dialog "popup" dcl_id)
(exit)
(start_list "selections")
(mapcar 'add_list NAMES)
(end_list)
(action_tile "accept"
(strcat "(getans)"
"(done_dialog) (setq userclick T)")
(action_tile "cancel"
"(done_dialog) (setq userclick nil)"
(start_dialog)
(unload_dialog dcl_id)
(if userclick
(setq SIZ (fix SIZ))
(setq SIZ (nth SIZ NAMES))
(alert (strcat "You Selected: " SIZ))
This basically works great but I want it to be able to display
(i.e. In Mtext format if the user select both 01Monday & 02Tuesday
In the drawing...
01Monday
02Tuesday
2 seperate lines per entry
V-Man
« Reply #1 on: July 16, 2004, 09:32:42 AM »
I forgot this part of the code.
(defun getans ();;get values of controls & close the dialog
  (setq SIZ (atof (get_tile "selections")))
  (done_dialog 0)
Columbia
« Reply #2 on: July 16, 2004, 10:43:52 AM »
Okay.  There are a couple of things to address with this.  So here it goes.
1.)  the DCL control listbox returns a couple of different things depending on multiple select, when it is actioned, by either "action_tile" or "get_tile".  When multiple_select=false; then the value of the listbox is a string containing the integer relative to the selected index (i.e. "3" for the 4th item in the list) or "" (empty string) if none are selected.  When multiple_select=true; then the value returns the same as above when only one item is selected, however it returns a single string with all chosen indices concatenated delimited with spaces (i.e. "1 2 3" for the 2 thru 4 items selected).
[Are you following me so far?  Good...]
So what you need to do is take the value, parse out the indices, and have them refer back to your first list "NAMES".
2.) Then once you have the items of the list "NAMES" that you want, then you need to concatenate those values using a "\\P" between each to signify you want a new line.
Try that, and if you need help with the actual code, let us know...
V-Man
« Reply #3 on: July 16, 2004, 11:27:33 AM »
Even with my routine I cannot get it to return the multiple selections.
SMadsen
« Reply #4 on: July 16, 2004, 12:00:00 PM »
Dvarino, here's a small test with a multiple_select list box:
// DCL
popup : dialog {
  : list_box {
    key = "selections";
    multiple_select = true;
  ok_cancel;
;; AutoLISP
(defun C:Test ()
                "Thursday"     "Friday"       "Saturday"
                "Sunday"
  (if (not (new_dialog "popup" dcl_id))(exit))
  (end_list)
  (action_tile "selections" "(setq strLst (setItems $value NAMES))")
  (setq userclick (start_dialog))
  (and (= 1 userclick)
       (and strLst (princ strLst))
(defun setItems (val lst / ret)
  (foreach n (mapcar (function (lambda (n) (- n 48)))
                     (vl-remove 32 (vl-string->list val))
    (setq ret (cons (nth n lst) ret))
  (reverse ret)
It should return a list of the items that were chosen. If you don't like the MAPCAR thingie then the help files shows an alternative way of parsing the value of a multiple_select list box. It's in the section Managing Dialog Boxes -> List Boxes and Pop-up Lists -> Processing List Elements and is called MK_LIST.
V-Man
« Reply #5 on: July 16, 2004, 02:36:48 PM »
Thanks for the help but for some reason my list is a lot larger and it does not return the selected items.
    (setq agencynames '("01  Monday"     "02  Tuesday"    "03  Wednesday"
                  "04  Thursday"     "05  Friday"       "06  Saturday"
                  "07  Sunday" "xx  This" "xx  Does" "xx  Not" "xx Work"
If you try this multiple times using different scenarios you will see that it is not reporting what was selected.
SMadsen
« Reply #6 on: July 16, 2004, 07:54:22 PM »
Wow, that was somewhat of a blooper! Sorry. I must have fallen asleep while writing that.
Did you try the MK_LIST in the help files instead?
« Reply #7 on: July 17, 2004, 07:37:39 PM »
The multiselect method you are instigating may not suit the functionality you are trying to develop. The list returned from the get_tile call will be sorted numerically, not in selection sequence as you may expect.
This code may  be the simplest to return a list of values from the type of  string returned by the multiple selection list_box.
(setq tmp "2 4 6 9")
(read (strcat "(" tmp ")"))  ;; ==>> (2 4 6 9)
The first listing attached will do what you ask for .. multiple and single selection are valid.
The second listing will do what I think you want.
The third listing is some library stuff , plus the DCL
;;; Multiple Selection
(defun c:test0718b (/             dcl_id        index         names
                    starter       programpath   returnlist    objmtext
                    *error*       action-cancel do-something  action-accept
  (defun *error* (msg) (kbsf:debug-simple-error msg))
  (defun action-cancel (/) (princ))
  (defun do-something (/)
    (alert (strcat "You Selected: " returnlist))
    (setq objmtext (vla-addmtext kbsg:modelspace
                                 (vlax-3d-point '(0 0 0))
                                 0.0
                                 returnlist
  (defun action-accept (/ tmp tmpstr)
    (if (and (setq tmp (get_tile "selections"))
             (setq tmpstr     ""
                   returnlist (vl-string-right-trim
                                "\\P"
                                (foreach item (read (strcat "(" tmp ")"))
                                  (setq tmpstr (strcat tmpstr (nth item names) "\\P"))
      (done_dialog 101)
      (done_dialog 0)
  (setq programpath "z:\\_test\\List_box_Multiple_select\\"
                      "Sunday"         "08 Day Off"
    (not
      (new_dialog "dcl0718multiple"
                  (setq dcl_id (load_dialog (strcat programpath "dcl0718.dcl")))
     (exit)
  ;; -- initialise
  (mapcar 'add_list names)
  (end_list)
  (action_tile "accept" "(action-accept)")
  (setq starter (start_dialog))
  (cond ((= starter 101) (do-something))
        ((<= starter 0) (action-cancel))
;;; Selection in sequence
(defun c:test0718c (/ dcl_id          names           newstring
                      objmtext        programpath     starter
                      *error*         make-selection  action-cancel
  (defun make-selection (val /)
    (setq newstring (strcat newstring (nth (atoi val) names) "\\P"))
    (set_tile "newstring" newstring )
                                 0.0
                                 newstring
    (if (and (/= "" newstring)
             (setq newstring (vl-string-right-trim "\\P" newstring))
      (done_dialog 101)
      (done_dialog 0)
        newstring   ""
    (not
      (new_dialog "dcl0718single"
     (exit)
  ;; -- initialise
  (end_list)
  (action_tile "selections" "(make-selection $value )")
LIBRARY STUFF
(setq kbsg:debug_on t)
(or kbsg:acadapp (setq kbsg:acadapp (vlax-get-acad-object)))
(or kbsg:activedoc (setq kbsg:activedoc (vla-get-activedocument kbsg:acadapp)))
(or kbsg:modelspace (setq kbsg:modelspace (vla-get-modelspace kbsg:activedoc)))
(defun kbsf:debug-simple-error (msg / tmp)
  ;;----- Cancel any Active Commands -----------------------------
  (while (< 0 (getvar "cmdactive")) (command))
  (setvar "menuecho" 1)
  (vla-endundomark kbsg:activedoc)
  ;;----- Display error message if applicable
    ((not msg))
    ((member (strcase msg t)
             '("console break" "function cancelled" "quit / exit abort")
    ((princ (strcat "\nApplication Error: " (itoa (getvar "errno")) " :- " msg))
  (setvar "errno" 0)
  ;;----- Display backtrace
  (vl-bt)
  ;;----- Release Bound Activex Objects
  ;;  --- removed
  ;;----- Reset System Variables from global list
  ;;  --- removed
// dcl0718.dcl
dcl0718single
: dialog
label = "Test list_box" ;
: list_box
key = "selections" ;
multiple_select = false ;
: text
key = "newstring" ;
fixed_width = true ;
width = 70 ;
ok_cancel ;
dcl0718multiple
: dialog
: list_box
multiple_select = true ;
ok_cancel ;
V-Man
« Reply #8 on: July 19, 2004, 08:48:57 AM »
This is exactly what I want. Thanks for the hard work.
V-Man
« Reply #9 on: July 19, 2004, 08:51:19 AM »
How do you make it so that it asks the use to 'pick a point' to place the Mtext in stead of it places it at 0,0??
Anonymous
« Reply #10 on: July 19, 2004, 10:01:04 AM »
Perhaps something like this :
  (defun do-something (/ workpoint )
    (initget 1)
    (setq
      workpoint (getpoint "\n Specify MText insertion point : ")
                                 (vlax-3d-point workpoint)
                                 0.0
                                 newstring
« Reply #11 on: July 19, 2004, 10:03:52 AM »
Woops, not logged in :(
Just replace the do-something procedure with the one I posted should do the trick.
V-Man
« Reply #12 on: July 19, 2004, 10:31:28 AM »
I get this when i run the routine.
    Application Error: 10 :- ActiveX Server returned an error: Parameter not
    optional
    Backtrace:
[0.77] (VL-BT)
[1.73] (KBSF:DEBUG-SIMPLE-ERROR "ActiveX Server returned an error: Parameter
not optional")
[2.68] (*ERROR* "ActiveX Server returned an error: Parameter not optional")
[3.63] (_call-err-hook #<SUBR @0cbb9f50 *ERROR*> "ActiveX Server returned an
[4.57] (sys-error "ActiveX Server returned an error: Parameter not optional")
:ERROR-BREAK.52 nil
[5.49] (intelligent-invoke #<VLA-OBJECT IAcadModelSpace 0dc12c84> "AddMText" 1
#<variant 8197 ...> 0.0 nil)
[6.39] (#<SUBR @02674dd4 vlax-invoke-method> #<VLA-OBJECT IAcadModelSpace
0dc12c84> "AddMText" #<variant 8197 ...> 0.0 nil)
[7.31] (vla-AddMText #<VLA-OBJECT IAcadModelSpace 0dc12c84> #<variant 8197 ...>
0.0 nil)
[8.23] (DO-SOMETHING)
[9.19] (C:TESTB)
[10.15] (#<SUBR @0cbbe730 -rts_top->)
[11.12] (#<SUBR @026f2334 veval-str-body> "(C:TESTB)" T #<FILE internal>)
:CALLBACK-ENTRY.6 (:CALLBACK-ENTRY)
:ARQ-SUBR-CALLBACK.3 (nil 0)
[/list:u]
SMadsen
« Reply #13 on: July 19, 2004, 10:34:16 AM »
Quote from: Kerry Brown
That's a pearl! I'm gonna steal that, Kerry.
« Reply #14 on: July 19, 2004, 10:47:00 AM »
's ok, steal away Stig.  Just glad I have to have something worth borrowing ..
dvarino :
[7.31] (vla-AddMText #<VLA-OBJECT IAcadModelSpace 0dc12c84> #<variant 8197 ...>  0.0 nil )
indicate to me that the string is nil.
Any chance you tried the procedure as a stand alone :D
... if so, set the newstring value as a glogal variable to the text you want to add.
