Author Topic: Associative hatch won't stretch  (Read 7441 times)
Guest
« on: August 09, 2007, 01:31:21 PM »
I've got a DB of a bolt and I'm using a combination of stretch and array to make it look correct at various lenghts.  I've also got a hatch pattern thrown into the mix, but when I stretch the bolt, the hatch won't fill in.  The hatch pattern is set to "associative" so I don't know what else to look at.
See attached DWG.
Re: Associative hatch won't stretch
« Reply #1 on: August 09, 2007, 05:41:31 PM »
I could not get the hatch to stretch but here is one that arrays the pattern:
Birdy
« Reply #2 on: August 09, 2007, 06:01:36 PM »
I've had better luck when I hatch by "selecting object", rather than "pick (internal) point".
This requires your hatch area to be a closed polyline.
« Reply #3 on: August 09, 2007, 06:07:05 PM »
check your pickstyle variable...
Mr Cory
« Reply #4 on: August 09, 2007, 07:33:47 PM »
ronjonp's array solution is definatly the best as you are arraying the "boundary" its impossible for the hatch to remove associative to the boundary  :-)
Guest
« Reply #5 on: August 10, 2007, 08:19:48 AM »
Yeah... I like it.  I didn't even think about arraying the hatch.  I got so hung up on trying to make the stretch work.  Thanks guys!
Krushert
  • FREE BEER Tomorrow!!
« Reply #6 on: August 10, 2007, 09:42:18 AM »
Matt,
sweet anchor bolt.
If may suggest to kick it up a notch, have a seperate stretch the nut & washer in the other direction so that you can show this as holding something like the 2x4 as I am show in this piccy.   Just a suggestion  :-)
