I started a VBA command with a dialog box on an AutoCAD window . I hided the command (actually by using the Hide method from VBA , so the command didn't actually End) , changed to another and already opened window , and there I restore the dialog box .
The dialog came out and I pressed a button to hide it again (you see , my command is used to click on an image and insert a block) . The dialog got hidden and while on drawing space , I got the message :
Too many objects selected for INTERSECT
The command however run without any problems .
What was that ?
