Author Topic: Need more info on "Property Field Modifiers" in labels  (Read 8110 times)
« on: August 01, 2007, 09:15:11 AM »
I'm trying to change the way bearing labels are displayed and I'm looking for more information. So far all I've found in the documentation is under "Property Field Modifiers" but it doesn't list all the modifiers(?) that show-up in the editor.
For example, given the text
<[Tangent Direction(Udeg|FDMSdSp|MB|P4|RN|DSn|CU|AP|OF)]>what does the 'M' or all of the lower case characters mean?
What I want is => N 01°40'34" W
not => N01° 40' 34"W or => N01°40'34"W
thanks
Re: Need more info on "Property Field Modifiers" in labels
« Reply #1 on: August 01, 2007, 09:22:03 AM »
That would b set under Drawing Settings, Ambient Settings...for Bearings, and Directions
« Reply #2 on: August 01, 2007, 09:26:21 AM »
I see the same options there and no way to change it, at least none that I can see.
« Reply #3 on: August 01, 2007, 10:14:19 AM »
Another problem has arisen now. After changing "Direction" under "Drawing Settings --> Ambient Settings" to "long name" my Line labels show NORTH00°00'00"EAST, which is correct(?) but changing Direction back to "short name" doesn't affect the labels now. I'm stuck with "long name" now.
Dinosaur
« Reply #4 on: August 01, 2007, 10:17:08 AM »
I think your label is overriding the ambient setting.  In the label composer choose the course component from the list of elements.  You can specify the bearing display option there under format.
for the long name problem go back to the settings and make sure to apply the change and then select OK
« Reply #5 on: August 01, 2007, 10:25:33 AM »
Screen shot? 'cause I ain't seeing it. :)
I did that like three times, even closed and reopened the dwg. I fixed it by pasting the format from a text file I had.
Dinosaur
« Reply #6 on: August 01, 2007, 10:32:51 AM »
this help?
« Reply #7 on: August 01, 2007, 10:50:15 AM »
this help?
Not really, I've already tried that, but thanks for the screen shot. There "spaced" isn't the same as mine. :)
What I want .... N<space>01°40'34"<space>W what I get ... N01°<space>40'<space>34"W, two different animals.
thanks Dino
Dinosaur
« Reply #8 on: August 01, 2007, 10:53:38 AM »
I've never seen that one with spaces between everything.  I am still on 2007 so it may be a 2008 "enhancement".
« Reply #9 on: August 01, 2007, 10:59:53 AM »
You're right ... I must have had a brain fart or something.
« Reply #10 on: August 01, 2007, 11:05:41 AM »
Neither have I. That's what I'm trying to change. I see no way to edit the "format".
Dinosaur
« Reply #11 on: August 01, 2007, 11:09:10 AM »
It appears they have changed the definition of the format and I don't think there is a way to edit that else we could take care of the leading zero fiasco ourselves too.
« Reply #12 on: August 01, 2007, 11:18:32 AM »
Crap! That's right I forgot about the leading zero problem. Looks like it's back to my labels then.
« Reply #13 on: August 01, 2007, 11:21:03 AM »
I just set it and got no leading zeros....
Dinosaur
« Reply #14 on: August 01, 2007, 11:26:24 AM »
I think he is trying to get a space after that N and before the E without any spaces between the d m s numbers.  This was an option with 2007 but 2008 throws in the extra spaces.
