Author Topic: (Microstation) ID "Fields" in MS  (Read 2055 times)
PHX cadie
« on: July 14, 2007, 10:11:27 AM »
I know I'm jumping the gun being new to MS and I do have resources to find my own answers,   :oops: but I'm struggling with the basics, while my brain keeps jumping forward.
Is it possible to get the coordinates of point automatically in a table, in Microstation?  (w/o creating another data file and still doing the ole cut/paste).
Acad 2013 and XM
Arizona
Re: ID "Fields" in MS
« Reply #1 on: July 14, 2007, 10:12:54 AM »
Not that I'm aware of...but that doesn't mean much :-)
PHX cadie
« Reply #2 on: July 21, 2007, 05:56:55 PM »
Yeah Buddy.
same as ACAD, drag across a text, rt clk, object properties ! ! !
 :love:
Acad 2013 and XM
Arizona
« Reply #3 on: July 21, 2007, 07:26:37 PM »
So why are you doing this on a Saturday?
PHX cadie
« Reply #4 on: July 21, 2007, 08:05:44 PM »
Gatta give MS the same shot, besides, I have 10 days left on the trail version to catch up on 14 yrs of  Acad
(That and the j.o.b. may depend on it)
 You do know its your fault   :wink:
Acad 2013 and XM
Arizona
« Reply #5 on: July 22, 2007, 07:15:14 AM »
What? How? :angel:
And if it was fun, can I do it again?
PHX cadie
« Reply #6 on: August 20, 2007, 08:18:58 AM »
All right , lets do it again:
Seems this coordinate thing is not the format we like.
(with fields) By taking the properties of an object, the output is x,y,z. We need y,x and if necessary, just clip the z off. There is a xyz text that  outputs x,y,z, in 3 lines.
I'm trying to fit company Coordinate Data Table:
No.        Northing        Easting        Descrip.
1
2
3
What I've done using Fields is space the data evenly, reference that to the sheet, clip around all the "Y" coords, ref the file to the rt column, and clip around the "X" data, ref that to the 2nd column and have the No. and Descrip regular text in the sheet file.  Th Boss is not going to like it. I don't like, too complicated, too screwy. Is there a better way?
« Last Edit: August 20, 2007, 09:54:06 AM by PHX cadie »
Acad 2013 and XM
