Author Topic: Array action, no rows?  (Read 4925 times)
kim
« on: July 05, 2007, 01:50:40 PM »
Okay, Here I go again with dynamic block problems.  I am trying to create block of a Glu-lam beam that has horizontal lines every 3/4".  So I was trying to array those horizontal lines to fill in the beam as it gets bigger.  When I try to do an array action, it only gives me the options of "distance between columns" and not "distance between rows".  What am I missing, or is there an easier way to get the results that I need?
BAshworth
Re: Array action, no rows?
« Reply #1 on: July 05, 2007, 04:58:57 PM »
Design your glb sideways, and then have it rotated upon insertion.
Mr Cory
« Reply #2 on: July 06, 2007, 12:01:50 AM »
Yeah that is a little ambiguous. The direction of the array depends on the direction of the parameter that the array action is associated to
kim
« Reply #3 on: July 06, 2007, 06:09:11 PM »
Hmm, well, I tried it using  perameters going in both x and y directions, but creating it sideways just might work for now....Thanks.
