Author Topic: Open to directory not working anymore  (Read 2456 times)
ELOQUINTET
« on: June 20, 2007, 10:07:16 AM »
Hey guys I have this little lisp routine that would open explorer to the current folder but it has recently stopped working.
(defun C:DIRR ()(COMMAND ".BROWSER" (GETVAR "DWGPREFIX")))
I get the message:
createprocess:file not found
internet browser not found
I know it is probably due to the fact that I recently upgraded my internet explorer to 7 but how can I fix this?
Re: Open to directory not working anymore
« Reply #1 on: June 20, 2007, 10:54:41 AM »
See if this one works:
(defun c:dirr (/)
  (startapp "explorer" (strcat "/e," (getvar 'dwgprefix)))
ELOQUINTET
« Reply #2 on: June 22, 2007, 02:24:20 PM »
ah yes thank you so much ron. you never realize how much you miss something until it's gone. gracias
terrycadd
« Reply #3 on: June 22, 2007, 02:51:01 PM »
Now that's cool!  I use the keyboard shortcut [Windows_Key + E], which just brings up Explorer.  Now I need to add your idea to my shortcut commands.
Muchas Gracias.  Eres Rey!
Guest
« Reply #4 on: June 22, 2007, 03:10:10 PM »
I use a slightly different version which will automatically highlight the drawing in the Windows Explorer folder.
(defun C:WinExplorer ( / )
   (STARTAPP (strcat "EXPLORER /select, " (getvar "dwgprefix") (getvar "dwgname")", /e"))
« Reply #5 on: June 22, 2007, 03:14:52 PM »
I like it :)
Patrick_35
« Reply #6 on: June 23, 2007, 04:48:27 PM »
Hi
For the fun with Activex
(defun explore(dir / sh)
  (vlax-invoke-method (setq sh (vlax-create-object "Shell.Application")) 'explore dir)
  (vlax-release-object sh)
(explore "c:\\windows")
