Author Topic: DB with DB leader?  (Read 6621 times)
Guest
DB with DB leader?
« on: May 22, 2007, 11:50:05 AM »
Is it possible to have a DB with a leader attached that would only show up if the DB was moved a certain distance away from the insertion point?  Similar to spot elevations in Land Desktop?
Kate M
Re: DB with DB leader?
« Reply #1 on: May 22, 2007, 12:49:03 PM »
Not with OOTB functions, but you could probably get a reactor to trigger a visibilty state. Don't ask me how, but from the stuff going on at the Autodesk newsgroups, I think it'd be possible.
Mr Cory
« Reply #2 on: May 22, 2007, 06:22:52 PM »
I think Tlindell would be a good bet to talk to. It sounds like this is up his ally. Eg, when distance > make block objects 14,15,16 visible
whdjr
« Reply #3 on: May 23, 2007, 11:58:35 AM »
I'd like to know if you get something working or if I could help.  I can see some uses for this in our office.
LE
« Reply #4 on: May 23, 2007, 04:12:28 PM »
Don't have the La La Land Desktop but are you referring to what the QLEADER command does, when you start the leader and the length is less than the arrowhead, and is not drawn after the leader (leg) is greater than the arrowhead size? or I am doing my stuff in another tree?
Mr Cory
« Reply #5 on: May 30, 2007, 12:22:02 AM »
Hay Matt, i have been talking to Torrence, he said it is possible and if you could post a sample drawing on the autodesk disscussion group he can help you out  :-)
« Last Edit: May 30, 2007, 06:19:35 PM by Mr Cory »
Kate M
« Reply #6 on: May 30, 2007, 12:55:09 PM »
Are you two teaching at AU? If not, you should be...I'd be first to sign up!
Mr Cory
« Reply #7 on: May 30, 2007, 06:09:34 PM »
Who are you referring to Kate?
« Last Edit: May 30, 2007, 06:23:35 PM by Mr Cory »
Kate M
« Reply #8 on: May 31, 2007, 11:11:05 AM »
You and/or tlindell...I'm hoping for an "advanced DB" class this year. :-)
Mr Cory
« Reply #9 on: May 31, 2007, 07:53:22 PM »
  :-D Haha  :oops:  I wouldnt know where to start  :? Was there something specific you were after?
« Last Edit: May 31, 2007, 08:06:49 PM by Mr Cory »
tlindell
« Reply #10 on: August 04, 2007, 04:07:23 PM »
That's very nice of you to say, and if the situation was right where I could do such a thing, Dynblocks would be a very fun one to do.  Truthfully, I think it is much more informative to try working on the real world situations and meeting the challenge of solving it.  Forums like this are excellent collabrative environments for advanced DB learning.  If anything, DB's need to become more advanced:)
Mr Cory
« Reply #11 on: August 05, 2007, 04:27:38 PM »
 8-) Here Here   :-D
