Author Topic: Set all Blocks at 1 = 1  (Read 8825 times)
MSTG007
« on: June 24, 2004, 07:19:16 PM »
Set all Blocks at 1 = 1, when insert into dwg... you can tell it what size to be:)
Civil3D 2020
Dent Cermak
« Reply #1 on: June 24, 2004, 07:23:05 PM »
I draw my symbols up at 1 to 1. Then when I insert them at drawing scale the symbol appears on all of the plots as the same size.
« Reply #2 on: June 24, 2004, 07:33:40 PM »
Generally speaking I agree with Dent (wow, did I just say that?) -- create block symbology at 1:1, scale the instances.
Slim©
  • The Dude Abides...
« Reply #3 on: June 24, 2004, 07:41:39 PM »
Quote from: MP
Sometimes it happens, I've been agreeing with alot (not all) that he has to say in this forum.
I drink beer and I know things....
t-bear
« Reply #4 on: June 25, 2004, 07:58:30 AM »
Seems like this bunch has (for the most part) the same ideas as to what drafting "standards" should entail.
L:ike any other drawn object, a block should be 1=1.
CADaver
« Reply #5 on: June 25, 2004, 10:31:15 PM »
is there another way???
« Reply #6 on: June 26, 2004, 01:47:03 AM »
precisely .... if'n it is not 1:1 how would you effectively edit a typical block that didn't quite fit the bill?
