Author Topic: Move everything to #,#,0?  (Read 2879 times)
craigr
« on: March 20, 2007, 11:06:03 AM »
I would like to have a macro to move everything to zero on the Z axis.
1. Is there an problem with doing this?
2. I don't know how to do this. I know the 'draworder' thing, but as I understand it, that isn't really moving anything. I want to select everything in the dwg at once, and move it to zero on the z axis.
Do any of you already have a macro to do this?
Thanks in advance,
craigr
Arizona
Re: Move everything to #,#,0?
« Reply #1 on: March 20, 2007, 11:12:11 AM »
Hi Craig,
The problem with this method is that each type of object is stored differently.
In other words to move a line you must set the Z coordinate to zero for both the start and end point of the line. A circle, by it's center point, text by it's insertion point, etc...
I have a VBA program for this that works on lines, circles, arcs, text and mtext, that you are welcome to have. Just send me a PM if you are interested. :-)
craigr
« Reply #2 on: March 20, 2007, 11:14:45 AM »
Thanks for the offer, but alas, I am using LT  :cry:
LT doesn't use VBA or Lisps
craigr
Josh Nieman
« Reply #3 on: March 20, 2007, 11:20:41 AM »
I guess you don't have "flatten" eh?
craigr
« Reply #4 on: March 20, 2007, 11:23:09 AM »
'unknown command' - or were you joking?
Really, that is exactly what I want to do to the dwg.
craigr
Josh Nieman
« Reply #5 on: March 20, 2007, 11:33:12 AM »
craigr
nah, it's a real command for full autocad... but I think it is still an "express tools" command which means it's still just a lsp addin.  I don't see why they wouldn't add Flatten to LT... the whole purpose of the command is "Convert objects to 2d" which I would say would be most used BY LT users....
Gliderider
« Reply #6 on: March 20, 2007, 11:35:03 AM »
uncoolperson
« Reply #7 on: March 20, 2007, 11:35:09 AM »
have you tried using the properties window and changing all the x and y values?
(might work for a few... not everything, but some)
Arizona
« Reply #8 on: March 20, 2007, 11:46:24 AM »
Can you use qselect filtering?
filter for all lines...set start and end point z-coords
filter for all circles...set z-coord for centers,
etc...
craigr
« Reply #9 on: March 20, 2007, 12:44:08 PM »
Try here:
http://www.eng-tips.com/viewthread.cfm?qid=104669
The macro works great.
Thanks for the link.
The macro mentions '1e99' as the value of the 'z' axis. Does anyone here know what '1e99' is?
craigr
Arizona
« Reply #10 on: March 20, 2007, 01:03:23 PM »
The natural logarithm, formerly known as the hyperbolic logarithm, is the logarithm to the base e, where e is a certain constant approximately equal to 2.718281828459. The natural logarithm can be defined for all positive real numbers x as the area under the curve y = 1/t from 1 to x....
http://en.wikipedia.org/wiki/Natural_logarithm
So e raised to the 99th power?
Gliderider
« Reply #11 on: March 20, 2007, 01:17:43 PM »
1 to the 99th power. (1 exponent 99). From what I understand, acad can't work with such a large number, so it considers it 0. (I think)
Oops... 1 x 10 to the 99th power. 1 to the 99th power = 1
« Last Edit: March 21, 2007, 07:19:05 AM by Gliderider »
Tramber
« Reply #12 on: March 20, 2007, 01:21:45 PM »
Beleive it or not, the 1e99 (in Z) movement (and then back -1e99) is the official method from Autodesk to be used in LT.
This technic was created by Randy Richardson from Tee Square Graphics.
craigr
« Reply #13 on: March 20, 2007, 02:05:36 PM »
Holy Cow!!!
You folks are great! Is there anything you CAN'T answer?
Thanks for all of the responses,
craigr
Chuck Gabriel
« Reply #14 on: March 20, 2007, 04:59:47 PM »
Try here:
craigr
1e99 is scientific notation.  It means 1 x 10^99.
http://en.wikipedia.org/wiki/Scientific_notation
