Author Topic: Select sets variables [reference type]- an FYI  (Read 1902 times)
« on: March 09, 2007, 03:19:39 PM »
Selection set variables are set to the same object in memory.  Maybe some code might explain it better.  I just learned this today so I thought I would share.
 (lambda (/ ss ss1)
  (setq ss (ssget))
  (setq ss1 ss)
  (print (sslength ss))
  (print (sslength ss1))
  (ssdel (ssname ss 0) ss)
19
19
18
18
I didn't think this would happen, but after doing some coding in C# it seems that the variables 'ss' and 'ss1' are reference variables.  The both reference the same block of memory.
If anything I have stated is wrong, please let me know.
Re: Select sets variables [reference type]- an FYI
« Reply #1 on: March 09, 2007, 03:47:16 PM »
True story and good observation Tim. It's also why when you pass a selection set to a function you have to be careful (because it's treated as a reference).
Brief illumination:
(   (lambda ( / foo ss )
        (defun foo ( ss )
            (if (and
                    (eq 'pickset (type ss))
                    (< 0 (sslength ss))
        (if (setq ss (ssget "x"))
                (princ
                    (strcat
                        "Selection set ss's length before (foo ss): "
                        (itoa (sslength ss))
                        "\n"
                (foo ss)
                (princ
                    (strcat
                        "Selection set ss's length after (foo ss): "
                        "\n"
            (princ "Errrm, try this in a dwg with some entities.")
Not suggesting you don't know this Tim; it's for the benefit of those that might not.
« Reply #2 on: March 09, 2007, 03:52:57 PM »
Brief illumination:
<snip>
Thanks for that Michael.  I didn't even think of that, but it makes good sense when I do.  :-D
Glad to see you posting again, hope all is/was well and good with you.
