Author Topic: How obtains "JOIN" the order, returns to "T" OR "NIL" the value?  (Read 4824 times)
hunterxyz
Re: How obtains "JOIN" the order, returns to "T" OR "NIL" the value?
« Reply #1 on: March 02, 2007, 07:24:56 PM »
Sorry, try as I might, I can't understand the question.
« Reply #2 on: March 03, 2007, 09:58:59 AM »
You're not alone.
Looked at this 3 different times & don't have a clue. :?
Welcome to the swamp hunterxyz.
Please try again with your question.
« Last Edit: March 03, 2007, 10:00:37 AM by CAB »
Crank
« Reply #3 on: March 03, 2007, 11:18:07 AM »
I think hunterxyz wants T as a result when the join command was succesfull and nil when it failed.
hunterxyz
« Reply #4 on: March 03, 2007, 08:22:58 PM »
TYPE1:
JOIN EN1 AND EN2 TO EN1
_$ T OR _$ nil
JOIN EN1 AND EN3 TO EN3
_$ T OR _$ nil
TYPE2:
JOIN EN1 AND EN3
_$ T OR _$ nil
JOIN EN3 AND EN2
_$ T OR _$ nil
Result Why is same?
How can judge is different?
« Reply #5 on: March 03, 2007, 09:33:06 PM »
show me the code you are using.
« Reply #6 on: March 03, 2007, 09:37:05 PM »
hunterxyz,
Sorry, I can't understand what you are saying
Why so many different EN1's and EN2's and EN3's ?
What is ENA and ENB ?
hunterxyz
« Reply #7 on: March 03, 2007, 10:48:55 PM »
(setq ENA (CAR (ENTSEL "\n SELECT OBJECT A:")))
(setq ENB (CAR (ENTSEL "\n SELECT OBJECT B:")))
(vl-cmdf ".JOIN" ENA ENB "")
_$ T
_$ T
(COMMAND ".JOIN" ENA ENB "")
_$ nil
_$ nil
« Reply #8 on: March 03, 2007, 11:01:37 PM »
That is the difference between using
(vl-cmdf
and
(COMMAND
... which is a different question to your original post and different to the Picture you posted.
« Reply #9 on: March 03, 2007, 11:04:15 PM »
vl-cmdf returns T if the command executes successfully.
command always returns nil
EDIT: Kerry beat me to it.
« Reply #10 on: March 03, 2007, 11:05:37 PM »
Have a look ..
hunterxyz
« Reply #11 on: March 03, 2007, 11:25:04 PM »
Therefore, "vl-cmdf" and "command" returns,Forever is this value.
Is unable to judge "JOIN" whether succeeds.
Is this?
« Reply #12 on: March 03, 2007, 11:44:41 PM »
(defun c:test()
  (not(and (entget ena) (entget enb)))
« Reply #13 on: March 03, 2007, 11:51:08 PM »
(NOT (AND (ENTGET ena) (ENTGET enb)))
yep, was just posting that CAB
hunterxyz
« Reply #14 on: March 04, 2007, 03:34:16 AM »
Thank you the reply
