I'm finally starting to get my feet wet with the Sheet Set Manager - and like McDonald's I'm loving it!!
Anywho....I've got a handful of subsets set up and was wondering if there's a way to make a subset exempt from the sheet list table? For instance, I've got subsets of my plan drawings and a subset of the xrefs. I don't want the xrefs to show up in the sheet list table. Can this be done - without having to delete the unwanted sheets from the table afterwards? It makes updating the table all the more difficult.
Why do you have your XREFs in a subset in your SSM?
The sheets in the SSM should only be the sheets in your drawing set, i.e. your "plot" drawings and layouts, not your "model" drawings. Basically, 1 page in SSM = 1 printed page in your final plan set.
The SSM is not intended for PM, and is not really intended to manage your model files, except with respect to the Views. But the View management is not really intended to help manage your model drawings. Again, we're back to the same old boat where Vanilla Autocad desperately needs full-fledged PM support added to it, and then the SSM should be integrated with the PM support. But it may be a long, long time before Autodesk does
that... They're hooked on this "Vault" thing.
