Author Topic: Strcat text with a list  (Read 3123 times)
Cawaugh
« on: January 02, 2007, 11:06:45 AM »
(write-line (strcat "(find_replace " includetxt " " mdwg " " mstringlist " " SearchAtt " " case " " firstonly ")") Ofil)
The above gives me an error which I believe is due to trying to strcat text with lists. mstringlist and SearchAtt are lists. How can I get these lists into a script file with write-line? What I am trying to do is pass a list as an argument to the find_replace function. When the script is run it has this as a line to be read:
(find_replace "1" "y" list-of-strings-to-look-for list-of-atts-to-search-through "1" "1")
Thanks in advance for any help. :-)
Re: Strcat text with a list
« Reply #1 on: January 02, 2007, 11:27:28 AM »
Chuck,
  When you want to string characters (strcat) and an item is a list, use 'vl-princ-to-string' for that item.  So something like
(strcat
 "Happy"
 (vl-princ-to-string '(1 2 3 45))
 (setq Test " This is a test. ")
Returns
"Happy(1 2 3 45) This is a test. "
Hope that helps.
« Reply #2 on: January 02, 2007, 11:54:26 AM »
Breaking this down:
It would appear that find_replace takes several string arguments
And returns a string that is then written to a file.
If that is the case then no strcat is needed.
(write-line (find_replace " includetxt " " mdwg " " mstringlist " " SearchAtt " " case " " firstonly ") Ofil)
If that is not the case then more information on the find_replace function is needed.
« Last Edit: January 02, 2007, 11:55:30 AM by CAB »
Cawaugh
« Reply #3 on: January 03, 2007, 09:57:46 AM »
Chuck,
(strcat
 "Happy"
Returns
Hope that helps.
What I am finding out is that I cannot get a list written out so that when the script is run the below setq will not work. I'm trying to set the variable mstringlist to a list but the strcat won't let me.
(write-line (strcat "(setq " "mstringlist " mstringlist ")") Ofil)
« Reply #4 on: January 03, 2007, 11:15:29 AM »
Maybe this
(write-line
 (strcat
  "(find_replace "
  includetxt
  mdwg
  (vl-princ-to-string mstringlist)
  (vl-princ-to-string SearchAtt)
  case
  firstonly
 Ofil
« Reply #5 on: January 03, 2007, 11:59:28 AM »
Boy, I sure missed that one. :-o
« Reply #6 on: January 03, 2007, 12:14:08 PM »
Thats okay, you can have the next one then  Alan.   :-D
