Author Topic: XP will not support Autocad 2000?  (Read 3068 times)
Astro
« on: December 25, 2006, 10:27:36 PM »
Santa Clause brought me a new desktop when I tried to load my Autocad 2000 to this is the message that I got.
"System requirements error"
"Wrong OS, AutoCad supports Window NT 4.0, Windows NT 5.0, Windows 95, and Windows 98.
Anyone else run into this problem?
Barry
Re: XP will not support Autocad 2000?
« Reply #1 on: December 25, 2006, 10:45:16 PM »
You cannot load AutoCAD 2000 on Windows XP Home, and AutoCAD 2000 is no longer supported by Autodesk. I am not aware of any workaround allowing its installation.
Astro
« Reply #2 on: December 25, 2006, 11:04:38 PM »
What version of Autocad can I use on this machine?
« Reply #3 on: December 25, 2006, 11:25:31 PM »
« Reply #4 on: December 25, 2006, 11:34:03 PM »
Good answer Alan ... on several levels ;-)
Bob
« Reply #5 on: December 26, 2006, 07:53:21 AM »
I think you might find that unless you are a power user or administrator, It will not work.
We have it running on XP Pro
CADaver
« Reply #6 on: December 26, 2006, 09:48:51 PM »
I ran it on XP home for some time.  As I recall there were instructions in the R2000 literature explaining the installation process, basically ignore the error message and forge ahead.  There was a small quirk with the MTEXT infernal editor... umm inTERnal editor, but switching to NOTEPAD fixed that.
Dilbert
« Reply #7 on: December 27, 2006, 08:22:53 AM »
Try using the Windows Program Compatibility Wizard.
Go to Start - Help and Support
Type: Compatibility
An option should appear that states: Getting Older Programs to run on Windows XP.  In there will be a link to your Compatibility Wizard. Follow the steps, it will trick (in many cases) your program to believe that you are running an older version of Windows which may solve your issue.
Astro
« Reply #8 on: December 27, 2006, 11:53:57 AM »
Thank You so much.  I have it running now. Whew!! You guys are great!! Merry Christmas and Happy New Year!
barry (The human that Astro trains)
