Author Topic: Map & Disconnect Drives  (Read 1729 times)
Kheilmann
« on: December 22, 2006, 03:53:13 PM »
Is it possible to map & disconnect a \\Server\Folder\ to/from a drive letter?
David Hall
  • Automatic Duh Generator
Re: Map & Disconnect Drives
« Reply #1 on: December 22, 2006, 04:35:29 PM »
this might get you started
Set WshShell = WScript.CreateObject("WScript.Shell")
Set WshNetwork = WScript.CreateObject("WScript.Network")
Set AllDrives = WshNetwork.EnumNetworkDrives()
DriveLetter = "N:" 'must be capitalized
RemotePath = "\\server\share"
AlreadyConnected = False
For i = 0 To AllDrives.Count - 1 Step 2
If AllDrives.Item(i) = DriveLetter Then AlreadyConnected = True
Next
If AlreadyConnected = False then
WShNetwork.MapNetworkDrive DriveLetter, RemotePath
WshShell.PopUp "Drive " & DriveLetter & " connected successfully."
Else
WShNetwork.RemoveNetworkDrive DriveLetter
WshShell.PopUp "Drive " & DriveLetter & " disconnected."
End if
« Last Edit: December 22, 2006, 04:37:34 PM by CmdrDuh »
jjs
« Reply #2 on: March 02, 2007, 01:16:03 AM »
YES.
Sorry, could not resist. I have a whole app that does this. You can use an INI file to load the paths you want and then map and unmap which ones you want by checking the boxes. Let me know if you are interested and I will see if I can find the code.
