Author Topic: XREF layers on/off  (Read 3349 times)
VerticalMojo
XREF layers on/off
« on: May 19, 2004, 05:06:54 PM »
Im kinda troubled here.....
I have a Xref Schematic with a demo layer turned off. They Xref multiple dwgs....
On one dwg I leave the demo layer turned off....
On another I have it turned on.....
My question is on some drawings I save the dwg with the demo layer turned on.... but when I open it the demo layer is turned off..... It must be a variable or something cause this only occurs on some drawings....
Its prolly something real easy.... can some one explain this???
Thanks.....
Dent Cermak
XREF layers on/off
« Reply #1 on: May 19, 2004, 05:14:39 PM »
When you turn it off, it is off. When you turn it on, it is on. Next question.
VerticalMojo
XREF layers on/off
« Reply #2 on: May 19, 2004, 05:19:55 PM »
not sure if Im saying this right.....
My xref demo layer is off.... Drawing "A" & "B" use it as a Xref
Drawing "A" leaves it off
Drawing "B" has it on, but when I save, close, then open the same dwg.... the layer is turned off....... I cant get it to save the layer changes....
Am I making any sense??????
Sitra
XREF layers on/off
« Reply #3 on: May 19, 2004, 05:23:18 PM »
Try visretain.
t-bear
XREF layers on/off
« Reply #4 on: May 19, 2004, 05:30:22 PM »
Is the demo layer on or off in the xref dwg?  I *THINK* visretain=1 will solve your problem but you might try turning demo on in the xref.....
VerticalMojo
XREF layers on/off
« Reply #5 on: May 19, 2004, 05:30:52 PM »
Yup that does the trick....... :dood:
Wierd though....
On the drawing that worked and saved its changes... VISRETAIN had a variable of "0"....
But on the ones that wouldnt save I had to change the variable to "1"......
Anywho, Thanks
VerticalMojo
XREF layers on/off
« Reply #6 on: May 19, 2004, 05:33:28 PM »
To answer you T-Bear, the demo layer is off in the Xref dwg...
