Author Topic: Aline Block to polyline..  (Read 3676 times)
Andrea
« on: December 05, 2006, 11:36:58 AM »
Hi all..
Before making a new program..
I would like to see if is exist..
the program must aline all selected block to a polyline in one selection..
(see sceenshot)
If any of you know any program doing something similar..i'll be glad to see it.
thanks every  one and have a good day.  :angel:
Keep smile...
Guest
Re: Aline Block to polyline..
« Reply #1 on: December 05, 2006, 11:46:38 AM »
Two things that come to mind are:
1) The measure command and
2) Use the ALIGN parameter of Dynamic Blocks.
« Reply #2 on: December 05, 2006, 12:02:31 PM »
I was thinking measure first, but then I looked at the picture, and I don't think measure would work, as it only allows one distance between blocks, and in the pic they are not evenly spaced.
Guest
« Reply #3 on: December 05, 2006, 12:04:36 PM »
I guess that brings up the question: 'Do they NEED to be spaced evenly or can they be more sporadic?'
« Reply #4 on: December 05, 2006, 12:10:59 PM »
I looks like it is one per segment of the polyline.  Just a guess though.  And I haven't dug into dynamic blocks yet, so if you know that the align property would work, then I would think one would just need to write the routine to insert them per segment, and then use the align property.  Doesn't make it sound to hard.
LE
« Reply #5 on: December 05, 2006, 12:15:20 PM »
Here is a start:
(setq ename (car (entsel "\nSelect block: ")))
(setq curve (car (entsel "\nSelect polyline: ")))
(setq pt (getpoint "\nPoint insertion: "))
(setq param (vlax-curve-getparamatpoint curve pt))
(setq a (vlax-curve-getpointatparam curve (fix param)))
(setq b (vlax-curve-getpointatparam curve (1+ (fix param))))
(vla-put-rotation (vlax-ename->vla-object ename) (angle a b))
HTH
Andrea
« Reply #6 on: December 05, 2006, 01:43:53 PM »
Thanks LE..
I use your code..
(defun c:Qalin ()
 (setq bname (ssget '((0 . "INSERT"))))
  (if (not bname)
      (alert " Aucune entité n'a été sélectionné.")
      (exit)
    (bnamecheck)
(defun bnamecheck (/ curve sscount val1 ename pt param a b )
(setq curve (car (entsel "\nSélectionnez votre Polyligne: ")))
  (if curve
(setq sscount (sslength bname))
(setq val1 (- sscount 1))
(repeat sscount
(setq ename (entget (ssname bname val1)))
(setq pt (cdr (assoc 10 ename)))
(vla-put-rotation (vlax-ename->vla-object (cdr (assoc -1 ename))) (angle a b))
(setq val1 (- val1 1))
(alert "Aucune Polyligne n'a été sélectionnée.")
Thanks guys.....i appreciate.
in fact can't use measure.....(not equal space between blocks..)
 :wink:
« Last Edit: December 05, 2006, 01:58:24 PM by Andrea »
Keep smile...
LE
« Reply #7 on: December 05, 2006, 02:13:53 PM »
You are welcome. :)
gile
  • Marseille, France
« Reply #8 on: December 05, 2006, 04:44:35 PM »
Perhaps I'm too late, but you can also use vlax-curve-getFirstDeriv, it will work on polyarcs splines and so on ...
(setq deriv (vlax-curve-getFirstDeriv curve param))
(vla-put-rotation (vlax-ename->vla-object ename) (angle pt (mapcar '+ pt deriv)))
« Last Edit: December 06, 2006, 12:06:35 AM by gile »
Jochen
« Reply #9 on: December 06, 2006, 03:18:29 AM »
Seems to be similar to the TRAKTRIX-problem.
Regards
Jochen
www.black-cad.de
