Author Topic: Challenge - Distance between parallel lines  (Read 9061 times)
« on: October 31, 2006, 04:48:35 PM »
Ok, I think it is time for a challenge. This is an exercise in something that you may need from time to time.
Create a function that takes a point on a line then calculate the distance between that line and the closest parallel line on the same layer.
The function should accept two arguments, a point and a maximum distance to search away from the initial point, and should return a real number indicating the offset distance of the parallel line. Something extra would be to limit the search to only those items that intersect a perpendicular point to the original point.
example:
(findparallel basepnt 120)
Result would be nil for nothing within 120 units parallel to the point and the distance for the closest line within 120 units.
gile
  • Marseille, France
Re: Challenge - Distance between parallel lines
« Reply #1 on: November 01, 2006, 05:37:48 AM »
Here's my code, it works in WCS plane, "the search is limited to only those items that intersect a perpendicular point to the original point."
Edit : It works now in every UCS plane containing the line.
(defun findparallel
       (basept leng / ss elst lay start end ang p1 p2 linelst)
    (and (setq ss (ssget basept '((0 . "LINE"))))
(setq elst (entget (ssname ss 0)))
(setq basept (osnap basept "_nea"))
(setq lay (cdr (assoc 8 elst)))
(setq start (trans (cdr (assoc 10 elst)) 0 1))
(setq end (trans (cdr (assoc 11 elst)) 0 1))
(equal (caddr start) (caddr end) 1e-9)
(setq ang (angle start end))
(setq p1 (polar basept (+ ang (/ pi 2)) leng))
(setq p2 (polar basept (- ang (/ pi 2)) leng))
(setq
   ss (ssdel (cdr (assoc -1 elst))
     (ssget "_X" (list '(0 . "LINE") (cons 8 lay)))
(setq linelst
(vl-remove-if
  '(lambda (l)
     (or
       (not
(inters (trans (cdr (assoc 10 (entget l))) 0 1)
(trans (cdr (assoc 11 (entget l))) 0 1)
p1
p2
       start
       end
       nil
  (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
     (apply
       'min
       (vl-remove-if
'(lambda (x) (< leng x))
(mapcar '(lambda (l)
    (distance
      basept
      p1
      p2
linelst
(defun c:test (/ pt sd dist)
  (setq pt (getpoint "\nPick a point on a line: ")
sd (getdist pt "\nSearch distance: ")
    (setq dist (findparallel pt sd))
     (princ (strcat "\nClosest parallel line at: " (rtos dist)))
     (princ "\nNothing found.")
« Last Edit: November 01, 2006, 03:31:09 PM by gile »
« Reply #2 on: November 01, 2006, 10:11:26 AM »
gile
I am having trouble getting your routine to return other than 0.
Test: Draw a line 0,0 to 120,0 then a line 0,10 to 120,10 both on layer 0
(findparallel (setq pt (getpoint)) 200)
result 0
WCS
No other geometry in model space
osnaps set to end & mid
picked on end of line & another at mid point
FYI
Here are a couple of problems I have encountered in the past
Lines may be parallel but of different lengths
Lines may be parallel but drawn from opposite directions.
LE
« Reply #3 on: November 01, 2006, 10:22:11 AM »
Here is my contribution - warning: not fully tested -
(defun parallelPts  (lst sp ep / p1 p2)
  (setq p1 (car lst)
p2 (cadr lst))
  (if (equal (angle sp ep) (angle p1 p2) 0.0001)
    (list p1 p2)
    (list p2 p1)))
(defun C:TST  (/ ss start ename p10 p11 layer end ename2 pars da db
       search_dist)
  (if (setq start (getpoint "\nStart from: "))
      (if (not def)
(setq def 1.0))
      (setq search_dist
     (getdist start
      (strcat "\nSearch distance <" (rtos def) ">: ")))
      (if (not search_dist)
(setq search_dist def)
(setq def search_dist))
      (setq ss (ssget start))
      (if (and ss (= (sslength ss) 1))
  (setq ename (ssname ss 0)
p10   (cdr (assoc 10 (entget ename)))
p11   (cdr (assoc 11 (entget ename)))
layer (cdr (assoc 8 (entget ename)))
start (polar start
     (+ (angle p10 p11) (* pi 1.5))
     search_dist)
end   (polar start
     (+ (angle p10 p11) (* pi 0.5))
     (* search_dist 2.0)))
  (if (setq
ss (ssget "f"
  (list start end)
  (list (cons 8 layer) (cons 0 "LINE"))))
      (setq ss    (ssdel ename ss)
    ename2 (ssname ss (- (sslength ss) 1))
    p1    (cdr (assoc 10 (entget ename2)))
    p2    (cdr (assoc 11 (entget ename2)))
    pars
   (parallelPts (list p10 p11 p1 p2) p10 p11)
    da    (distance p10 (car pars))
    db    (distance p11 (cadr pars)))
      (if (equal d1 d2 0.000001)
  (redraw ename2 3)
  (getstring "\n<Enter> to unhighlight...")
  (redraw ename2 4)))))))))
  (princ))
And please, for these type of challenges, I would like to know/read/find out/etc. who won or what approach was better/close or have more potential.
In ALL the ones I have participated here - there is no final decision or a courtesy of saying "Hey that or that one was the algorithm or routine that was expected" - hope that this comment would help for future challenges.. I think.
« Reply #4 on: November 01, 2006, 10:29:40 AM »
That is a very good idea. Perhaps once the thread has run it's course, we can all come to a concensus of the good and bad, the most concise and perhaps the most unique method of solving the problem.
I'll give this particular thread about a week or so then we can discuss the particulars.
« Reply #5 on: November 01, 2006, 10:48:31 AM »
Luis,
I got this result on one of my test.
LE
« Reply #6 on: November 01, 2006, 11:07:03 AM »
Thanks, I look @ that in a while.... need to wash my car....
gile
  • Marseille, France
« Reply #7 on: November 01, 2006, 11:13:17 AM »
CAB,
I'm sorry, "x" was missing in (< leng x). I think it works now.
Here's another way, working in 3D, whatever the plane of lines or UCS.Some little vector and angular calculus routines have to be loaded.
I post them separately rather than include them in the code because I think these routines might be useful.
Edit : I changed the code for more concision and to add the possibility of "extra" :
New Edit : The routine have a now 3 arguments : base point, search distance and an option : T or nil.
(findparallel basept dist T) to specify that only lines crossing the perpendicular plane to original line at picked point are searched ("extra")
(findparallel basept dist nil) overwise.
Sub routines :
;;; Returns the single unit vector from p1 to p2
(defun VEC1 (p1 p2)
  (if (not (equal p1 p2 1e-009))
    (mapcar
      '(lambda (x) (/ x (distance p1 p2)))
      (mapcar '- p2 p1)
;;; Returns an angle cosinus
(defun ACOS (num)
    ((equal num 1 1e-9) 0.0)
    ((equal num -1 1e-9) pi)
    ((< -1 num 1)
     (atan (sqrt (- 1 (expt num 2))) num)
;;; Returns the 3D angle defined by 3 3D points
(defun ANGLE_3PTS (som p1 p2 / d1 d2 d3)
  (setq d1 (distance som p1)
d2 (distance som p2)
d3 (distance p1 p2)
  (if (and (< 0 d1) (< 0 d2))
    (ACOS (/ (+ (* d1 d1) (* d2 d2) (- (* d3 d3)))
     (* 2 d1 d2)
;;; Returns the coordinates of a point's projection on a plane defined by its normal and origin
(defun PROJ_PT (pt org norm)
  (mapcar '-
  pt
  (mapcar
    '(lambda (x)
       (* x
  (cos (ANGLE_3PTS org (mapcar '+ org norm) pt))
  (distance org pt)
    zdir
Main function :
(defun findparallel
       (basept leng opt / ss elst lay zdir linelst intlst distlst)
(setq basept (trans (osnap basept "_nea") 1 0))
(setq zdir (VEC1 (cdr (assoc 10 elst)) (cdr (assoc 11 elst))))
(setq
(setq linelst
(vl-remove-if-not
  '(lambda (l / v)
     (setq v (VEC1 (cdr (assoc 10 (entget l)))
     (and
       (or
(equal zdir v 1e-12)
(equal zdir (mapcar '- v) 1e-12)
       (< (distance
    basept
    (vlax-curve-getClosestPointTo l basept)
  leng
(setq
   intlst
    (vl-remove-if-not
      'vl-consp
      (mapcar
'(lambda (l)
     (equal basept
    (setq
      proj (PROJ_PT
     (if (equal basept
     basept
     zdir
      basept
      (inters (cdr (assoc 10 (entget l)))
      basept
      proj
      opt ; T for "extra", nil overwise
linelst
(setq
   distlst
    (mapcar
      '(lambda (p)
(distance
   basept
   p
      intlst
     (apply 'min distlst)
  (print)
  (findparallel pt sd nil) ; or (findparallel pt sd nil)
« Last Edit: November 02, 2006, 04:28:20 PM by gile »
LE
« Reply #8 on: November 01, 2006, 11:16:26 AM »
Luis,
I copied the code from an old routine of mine, and forgot to rename two variables.
Should be:
(equal da db 0.000001)
Thanks.
« Reply #9 on: November 01, 2006, 02:14:01 PM »
OK, here is my offering.
Hope it works. :)
(defun c:getparallel (/ pt ent entss ss dis parlst elst elsts layfilter)
  ;;  CAB  02/05/06
  (defun parallel (ln1 ln2 pfuzz / ang1 ang2)
    (setq ang1 (angle (cdr (assoc 10 ln1)) (cdr (assoc 11 ln1))))
    (setq ang2 (angle (cdr (assoc 10 ln2)) (cdr (assoc 11 ln2))))
    (or
      (equal ang1 ang2 pfuzz)
      ;;  Check for lines drawn in opposite directions
      (equal (min ang1 ang2) (- (max ang1 ang2) pi) pfuzz)
  (while
      (initget 1)
      (setq pt (getpoint "\nSelect a point on the a line to find parallels."))
      (setq pt (list (car pt) (cadr pt))) ; 2d point
        ((null (setq entss (ssget pt '((0 . "LINE")))))
         (prompt "\nMissed line, try again.")
         t
        ((> (sslength entss) 1)
         (prompt "\nToo many lines at that point, try again.")
         t
        ((setq ent (ssname entss 0))
         nil
  (initget 7)
  (setq dis (getdist pt "\nEnter the search distance."))
  (setq elst (entget ent))
  (setq layfilter (assoc 8 elst))
  (setq ss (ssget "_C" (mapcar '(lambda (x) (+ x dis)) pt)
                       (mapcar '(lambda (x) (- x dis)) pt)
                       (list '(0 . "LINE") layfilter))
  (if (and ss (> (sslength ss) 1))
      (setq elsts
             (mapcar 'entget
                   (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))
      (foreach ent (vl-remove elst elsts)
        (if (parallel elst ent 0.0001)
          (setq parlst (cons (cdr (car ent)) parlst))
      (if parlst
          (setq parlst (cons (cdr (car elst)) parlst))
          (mapcar '(lambda (x) (redraw x 3)) parlst)
          (getpoint "\n<Enter> to unhighlight...")
          (mapcar '(lambda (x) (redraw x 4)) parlst)
        (prompt "\n***  No lines parallel, Bye.")
    (prompt "\n***  No lines matching Layer, Bye.")
gile
  • Marseille, France
« Reply #10 on: November 01, 2006, 02:46:36 PM »
Your routines works fine, but I thaught the routine should return the distance to the closest parallel line within the search distance or nil.
Did I misunderstand ?
« Reply #11 on: November 01, 2006, 03:12:33 PM »
Shoot, I was just happy to find the parallel lines.
Let me revise the code. :-)
« Reply #12 on: November 01, 2006, 03:14:02 PM »
You are correct. The return value should be either nil or the distance to the closest parallel line on the same layer.
« Reply #13 on: November 01, 2006, 03:48:59 PM »
Here we go again.
(defun getparallel (pt dis / ent entss ss mdist parlst elst elsts layfilter)
  ;;  CAB  02/05/06
    (or
    ((null (setq entss (ssget pt '((0 . "LINE"))))))
    ((> (sslength entss) 1))
    ((setq ent (ssname entss 0)))
  (if ent
          (setq elsts
                 (mapcar 'entget
          (if parlst
              (setq pt (vlax-curve-getStartPoint ent))
              (setq mdist (apply 'min
                         (mapcar '(lambda(x)
                             (distance (vlax-curve-getClosestPointTo x pt t) pt))
                               parlst)))
  mdist
Test routine.
(defun c:test (/ pt entss ent)
  (while
      (initget 1)
         t
         t
         nil
  (initget 7)
  (setq dis (getdist pt "\nEnter the search distance.\n"))
  (getparallel pt dis)
SomeCallMeDave
« Reply #14 on: November 01, 2006, 04:32:49 PM »
For what its worth, here is my attempt
(defun findParallel (pPoint pDistTol)
   (setq BaseLine (vlax-ename->vla-object (car (nentselp pPoint)))
         TestPoint (vlax-curve-getClosestPointTo BaseLine pPoint)
         TestAng (rem (vla-get-angle BaseLine ) pi)
         ss2 (ssget "X" (list (cons 0 "LINE") (cons 8 (vla-get-Layer BaseLine))))
         Count 0
         DistList nil
   );setq
   (ssdel (vlax-vla-object->ename BaseLine) ss2)
   (repeat (sslength ss2)
       (setq CurrEnt (ssname ss2 count)
             CurrAng (rem (vla-get-angle (vlax-ename->vla-object CurrEnt)) pi)
       );setq
       (if (equal CurrAng TestAng 0.001)
            (setq CurrDist (distance (vlax-curve-getClosestPointTo CurrEnt TestPoint T) TestPoint)
                  DistList (append DistList (list CurrDist))
            );setq
       );if
       (setq Count (+ Count 1))
   );repeat
   (setq MinDist (car (vl-sort DistList '<)))
   (if (<= MinDist pDistTol)
        MinDist
        nil
(defun c:TestFP()
  (findParallel (getPoint "\nPick Point on Line ") (getreal "\nEnter Distance Tolerance "))
