I tried to search the forum before I posted this but the search didn't work.
I am testing 2007 for our department before we roll it out. got the menus and such all sorted out, then I hit a printing snag. Our titleblocks are set to 30x42, meaning that we have points placed in the corners at 42x30 to keep the prints centered and page setups set to plot to extents, centered on the page. And before anyone asks, yes that is the printable area for our printers (at least what the driver reports as printable area). This arrangement has had zero issues with 2004 or 2005. 2007 does not like this though. It is showing negative values in the centering offset boxes when extents is checked and different values when I select a window using the points. I checked this on a new drawing, simply drew a rectangle 42x30 and the same thing happened, negative 0.0001812 (and a different value for the y direction) when printing to extents and 0.0 when printing to a window using the corners of the rectangle. Not sure I can see why.
Is there a setting or something that I am not seeing somewhere?
