Author Topic: Complete newbie question: Loading VB apps?  (Read 3111 times)
C. Alan
« on: October 14, 2006, 12:48:27 PM »
I am nearly a complete newbie to VBA.  I have written some code before, but it was for Virtual Pinball (a fun way to learn to code).  I have been working through some tutorials in the last few days, and I have one question that is really bugging me.
Most all of the tutorials involve running your VB Application from the VB editor.  So far, I have not been able to make the connection as to how to take my finished Application, and actually use it in autocad without having to open the VB editor.
I would like to be able to run my code from either the command line, or from a tool bar button.
Can some one point me to a good tutorial for loading, and executing your VB code in Autocad?
Thanks,
C. Alan
daron
Re: Complete newbie question: Loading VB apps?
« Reply #1 on: October 14, 2006, 01:34:49 PM »
C. I believe it can be done through a lisp call or as a macro in a toolbar. I'm pretty sure of this. Try typing vbarun or checking through the search with vbarun and selecting the lisp forum. I know it has been discussed before. However, weekends are usually pretty slow. You might check in over the week. I'm sure you'll get better answers than I can give.
Dinosaur
« Reply #2 on: October 14, 2006, 01:37:41 PM »
I had the same problem when I first started finding some VBA applications I wanted to try . . . I started looking around and found the VBALoad and VBARun commands.
  • Custom Title
Bryco
« Reply #4 on: October 14, 2006, 02:07:30 PM »
Mark's link covers most of it.
I use menus for most of my vba, as it is less noisy on the screen than a heap of toolbars.
Once you get over the rage, the Cui allows you to add to the menu fairly easily.
I also use lisp to create commands.
In notepad add
(defun c:LayerOff()
  (command "-vbarun" "Layers.LayerOff")
  (princ))
and save it as  LayerOff.LSP
Then in your acaddoc.lsp (Make one in notepad if you haven't one)
add the line
(autoload "LayerOff"         '("LayerOff"))
Now you have access to the command line, typing layeroff will run the sub of that name in the project you have loaded.
C. Alan
« Reply #5 on: October 14, 2006, 03:25:19 PM »
Thanks for the Link Mark, that was exactly what I was looking for.
Bryco:  Thanks for the lisp idea.  I know what you mean about the CUI, Between that and the problems we have had with the license server software, my office dumped its anual subscription last year.
--C. Alan
Bryco
« Reply #6 on: October 14, 2006, 03:52:25 PM »
  Hehe get those people at Autodesk where it hurts, :pissed:
« Last Edit: October 14, 2006, 03:54:18 PM by Bryco »
  • Custom Title
« Reply #7 on: October 15, 2006, 12:12:18 AM »
Very good! Welcome to theswamp ...........
C. Alan
« Reply #8 on: October 16, 2006, 01:05:16 AM »
Well, I have had some minor sucess with my first applicaiton.  I do a lot of hydrology work, and I wanted to make a macro that I could use to click on a closed poly line and get the area back in Acres.
I have gotten my macro to work, and I have attached it to a tool button.
I am currently using LDD 2004.  This is the code for my tool bar button
C^C-vbarun Area.dvb!Module1.AreaConvert
My code more or less looks like this:
Module1
Option Explicit
Sub AreaConvert()
Form1.show
Form1
Private Sub UserForm_Initialize()
Me.Hide
On Error Resume Next
With ThisDrawing.Utility
    .GetEntity Pick_Area, Pick_point, vbCrLf & "Select a closed polyline:"
        'Check for No Selection
        If Pick_Area Is Nothing Then
            .Prompt vbCr & "You did not pick anything."
            End
        End If
       'Check for Object type and Closed Polyline
        If Pick_Area.ObjectName = "AcDbPolyline" Then
            'nested if to check for closed polylines
            If Pick_Area.Closed = True Then
                Area_ft = Pick_Area.Area
                Area_Acres = Pick_Area.Area / 43559.45832
            Else
            .Prompt vbCrLf & "You did not pick a closed polyline."
            End
            End If
            Else
            End
        End If
        'test routine that were used durring development
    '.Prompt vbCrLf & "Object name " & Pick_Area.ObjectName
    '.Prompt vbCrLf & "selected point " & Pick_point(0) & "," & Pick_point(1)
    '.Prompt vbCrLf & "closed " & Pick_Area.Closed
End With
sqfoot.Caption = Area_ft
acres.Caption = Area_Acres
Me.show
The code executes more or less.  The only think I don't like is the command line echo that you see when you click on the toolbar button:
Command: -vbarun
Macro name: Area.dvb!Module1.AreaConvert
Command: Execution error
Is there anyway not to have these items echo to the command line?  What is the Execution error message mean?
Thanks,
C. Alan
« Reply #9 on: October 16, 2006, 02:13:50 AM »
What happens if you prefix the menu command with
^C^C^P
ie C^C^P-vbarun Area.dvb!Module1.AreaConvert
^P toggles MENUECHO on and off
/// kwb
