Ok, so I hae this huge school project and the Arch. has determined that there will be a base bid, an alternate #1, alternate #2.
Now this is fine well and good but the arch has set his up is mad. Xrefs inside of xrefs....this just makes me angry to start with... so after seperating everything, coloring as i would like them to be...i mad one new drawing and xrefed all the pieces together, and I had hoped that i could bind them all together with a bind-bind so that i would be left with very clearly differnt layer sets. as each of these drawings were sharing layer descriptions (ie. a-wall) this was a layer in each set the exist. biulding, the new section of building and the alternate sections. Now I hope you can see why i wanted to bind them so I had Ex.-a-wall, new-a-wall, and alt1-a-wall. well afer binding and all i thought i was in the home strect of setting up the hundred or so drawings that i need to create. well in creating the first sheet, I went in to try to freeze layers to make my floor plan, the dam things wont freeze and it keeps spitting out a message in the command line like :No matching layer names found. Damn well i though i left those bound xref as blocks in what i had hoped to be my xrefs. well i went and bursted the bound xrefs. to no avail. still same error. any suggestions...sorry so long winded just wanted to give as much info as possible!
