Author Topic: Removing C3D  (Read 4602 times)
Removing C3D
« on: October 02, 2006, 09:33:25 AM »
Anyone have any issues with removing C3D? The removal process of C3D fails miserably, even after repair.
Cannon
Re: Removing C3D
« Reply #1 on: October 02, 2006, 09:46:23 AM »
Version? Other stuff installed? OS? Virus scanner running? Phase of the moon?
Come on, you have to give us _something_ to go on.
Re: Removing C3D
« Reply #2 on: October 02, 2006, 10:00:57 AM »
C3D 2006, Raster 2006, LDT2006(removed OK). Just had WindowsXP SP2 installed last Friday. Norton Corp. AV running, I cannot turn it off. Tons of other stuff installed, MS Office 97, CAiCE ( latest edition ) and many more. Enabled/disabled the Windows system restore.
Error message;
Re: Removing C3D
« Reply #3 on: October 02, 2006, 10:09:08 AM »
BTW, yes I did reboot the computer.
Maverick®
Re: Removing C3D
« Reply #4 on: October 02, 2006, 10:12:15 AM »
You forgot...
http://imagiware.com/astro/moon.cgi
Just helpin ya out boss  :-)
Re: Removing C3D
« Reply #5 on: October 02, 2006, 10:17:23 AM »
Just found this, although .... nothing really in there.
[ http://discussion.autodesk.com/thread.jspa?messageID=5019738 ]
Re: Removing C3D
« Reply #6 on: October 02, 2006, 10:35:40 AM »
Never mind .... gonna do it the hard way. <delete>
thanks
Dent Cermak
Re: Removing C3D
« Reply #7 on: October 02, 2006, 01:26:46 PM »
LISTEN!! Is that a pack of wolves howling at the moon phot Mav posted or is that a bunch of AutoDesk salesreps bemoaning the uninstall of the "greatest software package this decade"?  :angel: ^-^
Cannon
Re: Removing C3D
« Reply #8 on: October 02, 2006, 04:58:25 PM »
Nah, 2006 sucked.  :-P
2007 now...
Dinosaur
Re: Removing C3D
« Reply #9 on: October 02, 2006, 06:20:16 PM »
Mark, I thought you were trying to get rid of it and had decided on the long road home which should have succeeeded by now.  What have you tried / accomplished, so far?
Re: Removing C3D
« Reply #10 on: October 05, 2006, 10:13:29 AM »
I removed 2006 and installed 2007. < jumping in with both feet > :-)
Dinosaur
Re: Removing C3D
« Reply #11 on: October 05, 2006, 10:33:33 AM »
Get BOTH of those feet wet . . . it should be a good move for you.  The only issue I have so far with 2007 after service pack 2 is converting down to older format drawings.
Bealerusa
Re: Removing C3D
« Reply #12 on: October 05, 2006, 12:18:27 PM »
Dino, what are your issues?  I have downloaded SP2 but have not installed it yet.  I have the need to often save down ( for clients...) and would like to know the woe before I go.  Thoughts??
Re: Removing C3D
« Reply #13 on: October 05, 2006, 12:23:34 PM »
The problem, for me, in saving down is that you lose ALL of your C3D objects and their "smarts". If you expect to get the drawing back and be able to use it as you were, fergetaboutit. Now if it's just so the client has the drawing as Acad objects, well, that would be OK since that's what they'd get.
My $0.02....
Bealerusa
Re: Removing C3D
« Reply #14 on: October 05, 2006, 12:36:09 PM »
AAhhh...  worth 0.04 to me, thanks Jeff.
