Author Topic: vla-get-arcsmoothness  (Read 2082 times)
« on: September 21, 2006, 11:05:43 AM »
So why does:
(vla-get-arcsmoothness
  (vla-get-activeviewport
    (vla-get-ActiveDocument (vlax-get-Acad-Object))
Corresponds to what the drawings viewres is set currently set to but when you use:
(vla-put-arcsmoothness
  5000
It changes the vla-get-arcsmoothness number but has no effect on the viewres number?
ElpanovEvgeniy
  • Moscow (Russia)
Re: vla-get-arcsmoothness
« Reply #1 on: September 21, 2006, 11:12:39 AM »
It is necessary to change customizations viewres and to make its current!
look
http://www.theswamp.org/index.php?topic=12382.msg153483#msg153483
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #2 on: September 21, 2006, 11:41:40 AM »
  (setq v (vla-get-activeviewport
            (setq doc(vla-get-ActiveDocument (vlax-get-Acad-Object)))
          ) ;_  vla-get-activeviewport
  ) ;_  setq
  5000
) ;_  vla-put-arcsmoothness
(vla-put-ActiveViewport doc v)
« Reply #3 on: September 21, 2006, 11:44:37 AM »
Thank you :). This is what i came up with.
(defun setvres (/ doc actvp)
  (setq doc   (vla-get-ActiveDocument (vlax-get-Acad-Object))
actvp (vla-get-activeviewport doc)
  (if (/= (vla-get-arcsmoothness actvp) 5000)
    (vla-put-arcsmoothness actvp 5000)
  (vla-put-activeviewport doc actvp)
(setvres)
