Author Topic: lines drawn on top of each other  (Read 2038 times)
drizzt
« on: June 06, 2006, 04:40:58 PM »
I have a drawing that has multiple lines drawn on top of each other. anyone know of a lisp, or command that will sort through a layer and delete all but one line. I am using LDD 2000.
M-dub
Re: lines drawn on top of each other
« Reply #1 on: June 06, 2006, 04:49:14 PM »
This one should help you...I believe
DELDUP.dcl
DELDUP.lsp
Lin-Z
« Reply #2 on: June 06, 2006, 04:50:01 PM »
Can't recall, but does LDD '00 have a map menu?  If so search for something called Map  Cleanup.  (I have no idea if it's in '00 tho)
VerticalMojo
« Reply #3 on: June 06, 2006, 05:00:06 PM »
If you have the express tools
express tools -> Modify -> delete duplicate objects
or I heard overkill is one.......
« Reply #4 on: June 06, 2006, 05:03:24 PM »
That is overkill.  :-D
VerticalMojo
« Reply #5 on: June 06, 2006, 05:05:23 PM »
oh  :roll:
drizzt
« Reply #6 on: June 06, 2006, 05:07:45 PM »
Thanks people...this will work
Slim©
  • The Dude Abides...
« Reply #7 on: June 17, 2006, 03:32:07 PM »
Overkill in the past has been known to mess up dimensions...
Just a bit o' caution. :-)
