There are 2 things that are bothering me, so I've decided to throw them out to experts. There may not be an answer to these questions since I can not completely explain exactly what I did but......(its also American Idol nite so why not post)
Do you keep Osnaps running? Good/bad?
There are times I will draw a boundary, usually plines, (no I'm not in the habit of c for closing, that would be one fix), but I always have Osnaps running (not nearest, apparent intersection or extension). Yet if I try to hatch, "boundary not found", sure enough after zooming in forever on each intersection, there will be one that is .0001 open. How does this happen with running Osnap?
Another nuisance is offset.
Currently in a Mechanical position I will offset from the centerline, 4" pipe, offset 2 each side. Yet the boss and myself have come back to a dwg and do a dist, it will be 3.9999999999. The boss is sensible enough to know no one in the bull pit is offsetting a line 1.99999995 each side to purposely get 2 lines 3.999999 apart. It is possible that once or twice when doing a dist I did not snap Per, but I also know I have. I've become so paranoid I'll set the UCS to the centerline then offset.
Like mentioned there may not be an answer, just thought I'd put it out there for discussion
