Author Topic: Dynamic Blocks Only Selection Set.  (Read 8868 times)
Shade
« on: May 10, 2006, 10:13:33 AM »
I was wondering if there is a way to select only the dynamic blocks in a drawing.
I could not see any DXF code for only dynamic blocks. Is there a way of filtering the normal blocks from the dynamic blocks?
Any help would be appreciated.....
Shade
:mrgreen:
Re: Dynamic Blocks Only Selection Set.
« Reply #1 on: May 10, 2006, 11:46:07 AM »
For starters, you could iterate the Blocks collection and check the IsDynamicBlock property and add the names of DynBlocks to a string which can be used in the SS filter. But, that still won't get any Dyn.Block inserts that have been Dynamically altered. For thos, the best you can do do right now is to include the block names beginning with a "*" and then compare the EffectiveName to your list of Dynamic Blocks.
I've been meaning to write a function to do just this, but have not had time......
« Reply #2 on: May 10, 2006, 12:07:40 PM »
« Reply #3 on: May 10, 2006, 06:41:09 PM »
Why does this not work?
(defun c:ddd (/ ename ss index obj)
  (setq
    ss   (ssget '((0 . "INSERT")))
    index -1
  (while (< (setq index (1+ index)) (sslength ss))
    (setq ename (ssname ss index)
  obj (vlax-ename->vla-object ename)
      (eq (vla-get-IsDynamicBlock Obj) :vlax-false)
       (ssdel ename ss)
  (sssetfirst nil ss)
« Reply #4 on: May 10, 2006, 06:59:47 PM »
When you remove an ename from the selection set you alter the order of the enames & therefore
corrupt your index.
« Reply #5 on: May 10, 2006, 07:49:42 PM »
Ron, as Alan said the counter messes things up if you remove an item AND increment the counter. Try this (untested):
  (setq
    index 0
  (while (and (setq ename (ssname ss index))
      (setq obj (vlax-ename->vla-object ename))
    (if (eq (vla-get-IsDynamicBlock Obj) :vlax-false)
      (ssdel ename ss);;remove non-Dynamic block from ss, counter stays the same
      (setq index (1+ index));;it is Dynamic, increment counter
  (sssetfirst nil ss)
« Reply #6 on: May 10, 2006, 08:27:44 PM »
Works like a champ Jeff :)
« Reply #7 on: May 10, 2006, 08:47:09 PM »
Just for fun, here's another way to skin the cat --
(ssget
    (append
       '((0 . "insert")(-4 . "<or"))
        (mapcar
           '(lambda (name) (cons 2 name))
            (   (lambda ( / result )
                    (vlax-for block
                        (vla-get-blocks
                            (vla-get-activedocument
                                (vlax-get-acad-object)
                        (if (and
                                (eq :vlax-false (vla-get-islayout block))
                                (eq :vlax-true (vla-get-isdynamicblock block))
                            (setq result
                                (cons (vla-get-name block)
                                    result
                    (if result result '(""))
       '((-4 . "or>"))
Reow!
:P
« Reply #8 on: May 10, 2006, 09:05:07 PM »
Michael, that's sort of what I suggested in my first response. Except you don't account for inserted blocks that have been dynamically altered. Once an alteration is done the insert becomes an Anonymous block, but is still linked back to the block definition by  the EffectiveName property.
Adesk sure didn't make it easy with these blocks......why not just include a DXF group that holds the Effective Name?
« Reply #9 on: May 10, 2006, 09:09:54 PM »
Guilty as charged -- didn't read all the responses. You're earlier response addresses the issue properly (e.g. I didn't know about the block names beginning with a "*" thing), but I'll leave my post, ignorant as it is rather than make your last one look out of place.
PS: I've never used dynamic blocks, does it show?
PS: As you note, dxf state flags, effective name etc. would have been nice; grrrr.
:ugly:
« Reply #10 on: May 10, 2006, 09:14:27 PM »
There was supposed to be an "apologies to Jeff / All" in that post.
« Reply #11 on: May 10, 2006, 11:47:46 PM »
Here is a way to use no index.
Sorry, not tested. I need sleep. :-o
(defun c:ddd (/ ename ss ssnew)
  (setq ss   (ssget '((0 . "INSERT"))))
  (while (setq ename (ssname ss 0))
    (if (eq (vla-get-IsDynamicBlock (vlax-ename->vla-object ename)) :vlax-false)
      (if (null ssnew) (setq ssnew (ssadd ename))(ssadd ename ssnew))
    (ssdel ename ss)
  (sssetfirst nil)
  (and ssnew (sssetfirst nil ssnew))
FengK
« Reply #12 on: May 11, 2006, 02:09:26 AM »
I was quite upset about this when I found out this.  I was very supprised that autodesk didn't think of it or purposely ignored it.  but seems it is becoming typical now, for autodesk to deliver half baked product.  i still enjoy using autocad, only with more and more disappointment.
« Reply #13 on: May 11, 2006, 09:28:54 AM »
    (ssdel ename ss)
  (sssetfirst nil)
CAB,
If you change the vlax-false to true it selects dynamic blocks :)
Ron
« Reply #14 on: May 11, 2006, 10:13:42 AM »
Oh good, you got it to work. :-)
;;  CAB 05/11/06
;;  returns a ss of user selected dynamic blocks or nil
(defun ssgetDynamicBlock (/ ename ss ssnew)
    (if (eq (vla-get-IsDynamicBlock (vlax-ename->vla-object ename)) :vlax-true)
    (ssdel ename ss)
  (sssetfirst nil) ; un-highlight all
  (and ssnew (sssetfirst nil ssnew)) ; highlite remaining
  ssnew
