Author Topic: setting scale and rotation upon insert?  (Read 8719 times)
ELOQUINTET
« on: March 02, 2004, 06:38:08 PM »
i have this macro and i am trying to fix the scale and rotation. i want my image to be inserted with a scale of 7.9036 and with a rotation of -90. how would i modify my macro to acheive this?
(command "-layer" "n" "0-IMAGE" "c" "WHITE" "0-IMAGE" ) ;setvar clayer "0-IMAGE";_imageattach
DEVITG
« Reply #1 on: March 05, 2004, 06:45:59 PM »
seem to be that _imageattach allways invoke the dialog box.
I do not know if there is a way to avoid the dialog box to show off.
« Reply #2 on: March 05, 2004, 08:53:15 PM »
You cannot use imageattach in this scenario you should use image....
Now to get the rest of the command parameters passed, you will need to..
1) Call image with a lisp function in your button... i.e. (command "image" ......)
2) Determine what the order of operation is for the image command. I don't use image (or imageattach for that matter) so right off the top of my head I cannot tell you.
3) Probably right after the attach command is issued,  you will need to specify insertion points and scales... you can use \ to pause (i think) and then hard code the scale...
Something like this ...
(command "image" "a") ;\ 90 7.9036
You will probably have to tweak it since I have not tested it....
DEVITG
image do too.
« Reply #3 on: March 06, 2004, 07:49:44 AM »
image invoke the dialog box too, a diferente but a dialog .
The trick would be how to tell acad not to show te dialog and acept command line input.
I had tryed all way , changing attdia , ccmddia, and cmdactive, Iset it to 0
but it still show the dialog box.
« Reply #4 on: March 07, 2004, 09:17:35 AM »
Here ya Dan.
(defun get-mspace ()
 (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object)))
(defun get-img-file ()
  (getfiled "Browse for Image file: " "" "" 8)
(defun c:img-insert (/ ms imgfile ins-pt image-obj)
  (setq ms (get-mspace)); modelspace object
  (if (setq imgfile (get-img-file))
    (if (setq ins-pt (getpoint "\nInsertion Point: "))
      (setq image-obj
             (vla-AddRaster ms
               imgfile
               (vlax-3D-point ins-pt)
               7.9036
               (* pi 1.50)
  (if image-obj
    (if (not (vlax-object-released-p image-obj))
      (vlax-release-object image-obj)
« Reply #5 on: March 07, 2004, 09:34:28 AM »
Forgot the layer part!
  (command "layer" "make" "0-IMAGE" "color" 7 "" "")
      (setq image-obj
             (vla-AddRaster ms
               imgfile
               7.9036
               (* pi 1.50)
  (if image-obj
« Reply #6 on: March 07, 2004, 02:56:29 PM »
I have had a bit of time to peruse this...
This works as well...
(command "image" "a" "imagename" pause "7.9036" "-90")
If you need to browse for the image, use....
(command "image" "a" (getfiled "Image to insert" "" "jpg" 8) pause "7.9036" "-90")
« Reply #7 on: March 07, 2004, 04:51:33 PM »
If you use the command -image and set filedia to 0 the dialogue doesn't pop-up.
Ron  :D
DEVITG
« Reply #8 on: March 07, 2004, 05:23:08 PM »
Hi Ronjop, I forget that the image was a file, and I did not consider the filedia as the variable to change. :oops:
Thanks for it :)
ELOQUINTET
« Reply #9 on: March 08, 2004, 01:10:37 PM »
hey mark i was using what i asked for for jpgs at home but i am trying to adapt your lisp to tiff files here at work. i figured out that to change the file type to browse for i had to change the 8 to 14. it's working but my question is why would it be assigning an anonymous name "OAImg1082920496" to it rather than the actual name of the scan "a-430"? here's what i have:
  (getfiled "Browse for Image file: " "" "" 14)
(defun c:I12 (/ ms imgfile ins-pt image-obj)
      (setq image-obj
             (vla-AddRaster ms
               imgfile
               387.25
               (* pi 1.50)
  (if image-obj
ELOQUINTET
« Reply #10 on: March 08, 2004, 01:17:02 PM »
it's not a big deal i was just wondering if it's an easy fix or no?
« Reply #11 on: March 08, 2004, 01:19:35 PM »
Don't use 14 Dan.
ELOQUINTET
« Reply #12 on: March 08, 2004, 01:32:46 PM »
ok changed it back to 8. for some reason when i had it as 8 before when i browsed it wasn't showing any tiffs so i thought this would fix that. now they are showing up with the 8, who knows? it's still giving the image a funky name and i can't see where it does that  :?:
« Reply #13 on: March 08, 2004, 02:16:24 PM »
what is the exact name of the file you are trying to insert?
ELOQUINTET
« Reply #14 on: March 08, 2004, 02:41:25 PM »
A-430 for this example. it varies though
