Author Topic: (ssadd) problem....  (Read 2396 times)
Andrea
(ssadd) problem....
« on: October 19, 2010, 05:43:17 PM »
Hi all,..
In AutoCAD 2011 with Vlide editor, If I run (setq ss (ssadd)) the function do not seem to work...
and can't close the editor,....it seem like there is some loop on it..
but,...If I type (setq ss (ssadd)) on the AutoCad command line....it seem to work.
Anyone have noted this ?
thanks.
Keep smile...
Re: (ssadd) problem....
« Reply #1 on: October 19, 2010, 06:04:30 PM »
No problem for me
win7x64ac2011
Andrea
« Reply #2 on: October 19, 2010, 08:06:24 PM »
Thanks Kerry,
i've tested on XP 32 Network Licence. AutoCAD 2011 SP2.1
AutoCAD 2010 seem to work.
Keep smile...
