Author Topic: Inventor 10 3D Models?  (Read 3084 times)
SDETERS
« on: April 27, 2009, 11:19:01 AM »
Does anyone here use Inventor 10?  If is so What type of files can you open with it?  We have Inventor 11 here but I need to get the file out to a inventor 10 format.  I know you can not go back only forward.  I have sent this customer many type of different files which they are all having trouble to open.  I would like to see if someone here would be interested and trying to open one of these files I am trying to send out.  Thanks
« Last Edit: April 27, 2009, 11:46:39 AM by SDETERS »
MickD
Re: Inventor 10 3D Models?
« Reply #1 on: April 27, 2009, 04:28:48 PM »
The best I can think of is a SAT file but you lose all you part info.
I can have a look later if you like (about 10 hours sorry, just got up and have to go to work)
- John Carmack
- J.R.R. Tolkien
SDETERS
« Reply #2 on: April 27, 2009, 04:53:48 PM »
That is cool
I will PM you the info.  Thanks
