Author Topic: Default Drawing On Autocad Startup  (Read 5482 times)
Willie
  • Going nowhere slowly
« on: October 11, 2007, 08:18:54 AM »
I everybody
Everytime I start Autocad, a drawing opens with it.  It is a drawing that I have been not been working on for at least a month now.  If I delete or rename the drawing, Autocad starts normally, without any error messages. The problem is, that the drawing is xrefed into other drawings and I can't deleted or renamed it.
Any suggestions on how to set Autocad so that no drawing opens when I start Autocad?
Soli Deo Gloria | Qui Audet Adipiscitur
Windows 8  64-bit Enterprise | Civil 3D 2015 and 2016| ArcGIS 10.1
Yogi Berra : "I'd give my right arm to be ambidextrous."
Gliderider
Re: Default Drawing On Autocad Startup
« Reply #1 on: October 11, 2007, 08:26:07 AM »
Startup=1
Willie
« Reply #2 on: October 11, 2007, 08:32:35 AM »
Startup=1
I have turned of the startup dialog the day that Autocad was installed. And it have always been like that for years now without any drawing opening when I start Autocad.
sinc
« Reply #3 on: October 11, 2007, 08:36:16 AM »
I actually don't know how you got it to open an existing drawing at all.
Typically, Autocad creates a new drawing during startup, unless you have STARTUP=1.  The new drawing is created from your QuickNew template, as specified in options.  If you have no QNEW template specified, Autocad creates a new "empty" drawing, using no template.
I didn't even know it was possible to get Autocad to open a specific drawing at startup.
Gliderider
« Reply #4 on: October 11, 2007, 08:46:36 AM »
On your desktop, rt-click on the icon you use to open Autocad; Properties. Is the drawing name specified in the Target box?
Willie
« Reply #5 on: October 11, 2007, 08:51:01 AM »
Find Target is set to : "C:\Program Files\AutoCAD 2006\acad.exe"
I know that you can set profiles and other options with that.
Take a look at http://www.hyperpics.com/downloads/resources/customization/general/AutoCAD%20Icon%20Switch.pdf
Another thing: What software are some of the guys using to do a screen capture in animated gif format? And is it freeware?
« Reply #6 on: October 11, 2007, 10:32:18 AM »
What version are you running?
peep the following:
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2867206&linkID=9240817  in case someone replaced your default dwt with the file name in question
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2895787&linkID=9240617 I think this is your Golden Ticket, perhaps you may need a new acad DWT to replace yours?
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2890335&linkID=9240617
