Out of what transpired in a thread on Autodesk's .NET
newsgroup, I made a minor enhancement to this class,
that allows you to set a static property, that when set
to true, causes the Command() method to automatically
insert "_non" into the command list, in front of Point3d
or Point2d arguments, to supress running osnaps.
I posted the update just now
Thanks for confirming that Tony.
I notice you've changed the TypedValueFromObject method to more refined code.
I'm still getting an InvalidCastException using the (int).... cast though.
When I use the Convert.ToInt32(ResTypes[t]) the methos executes without a qualm.
