Author Topic: Array by distance between 2 points  (Read 2226 times)
MSTG007
« on: August 19, 2015, 09:42:59 AM »
Can someone guide me on how to do an Array between a start point and an end point with a specified offset - interval or 10 feet or something? So as it stretches the array will only show the amount of the object every 10'? Something like that.
Civil3D 2020
MSTG007
Re: Array by distance between 2 points
« Reply #2 on: August 19, 2015, 10:04:59 AM »
Sometimes I just wanna..... Fill in the blank. Thank you very much.
Civil3D 2020
  • Custom Title
« Reply #3 on: August 19, 2015, 10:15:13 AM »
Use ARRAY with PATH & MEASURE option.
Command: ARRAY
Select objects: 1 found
Select objects:  Enter array type [Rectangular/PAth/POlar] <Path>: pa
Type = Path  Associative = Yes
Select path curve:
Select grip to edit array or [ASsociative/Method/Base point/Tangent direction/Items/Rows/Levels/Align items/Z direction/eXit]<eXit>: m
Enter path method [Divide/Measure] <Measure>: m
Select grip to edit array or [ASsociative/Method/Base point/Tangent direction/Items/Rows/Levels/Align items/Z direction/eXit]<eXit>: i
Specify the distance between items along path or [Expression] <1.000>: 26.355
Maximum items = 35
Specify number of items or [Fill entire path/Expression] <35>:
« Last Edit: August 19, 2015, 10:21:32 AM by Mark »
« Reply #4 on: August 19, 2015, 11:02:12 AM »
SURE....
« Reply #5 on: August 19, 2015, 11:03:19 AM »
SORRY, thought you were doing a dynamic block action set....
MSTG007
« Reply #6 on: August 19, 2015, 11:08:57 AM »
lol. dude it fine. I new that one.
Civil3D 2020
« Reply #7 on: August 19, 2015, 01:02:49 PM »
MSTG007
« Reply #8 on: August 19, 2015, 01:05:51 PM »
Nope! Thank you all for your expertise.
Civil3D 2020
Marco Jacinto
« Reply #9 on: August 19, 2015, 08:43:12 PM »
This is an old One, maybe it is still usefull, is in spanish.
What I try to acomplish was to mimic the way sketchup copies object between two points.
http://mcommands.blogspot.mx/2008/11/el-comando-car-es-una-copia-del-comando.html
Saludos
