Use ARRAY with PATH & MEASURE option.
Command: ARRAY
Select objects: 1 found
Select objects: Enter array type [Rectangular/PAth/POlar] <Path>: pa
Type = Path Associative = Yes
Select path curve:
Select grip to edit array or [ASsociative/Method/Base point/Tangent direction/Items/Rows/Levels/Align items/Z direction/eXit]<eXit>: m
Enter path method [Divide/Measure] <Measure>: m
Select grip to edit array or [ASsociative/Method/Base point/Tangent direction/Items/Rows/Levels/Align items/Z direction/eXit]<eXit>: i
Specify the distance between items along path or [Expression] <1.000>: 26.355
Maximum items = 35
Specify number of items or [Fill entire path/Expression] <35>:
