Author Topic: Help to Modify a LISP  (Read 5689 times)
RolandOrzabal
  • "memories fade but the scars still linger"
Re: Help to Modify a LISP
« Reply #15 on: November 05, 2012, 07:52:08 PM »
Thanks Lee! revised code below but nothings happening...wonder whats wrong..
or is it on my side?
 (defun c:LayAllThaw  ()
   (vlax-for lay  (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object)))
     (vla-put-Freeze lay :vlax-false))
   (princ))
 (defun c:LayAllOn  ()
     (vla-put-LayerOn lay :vlax-true))
   (princ))
 (defun c:LayAllShow () (c:LayAllThaw) (c:LayAllOn))
 (setq *LayUnHide-StateName* "*LayerUnHide*")
 (defun c:LayUnHide  (/ *error* LayersToTurnOn en)
   (defun *error*  (msg)
     (if (layerstate-has *LayUnHide-StateName*)
       (progn (layerstate-restore *LayUnHide-StateName* nil) (layerstate-delete *LayUnHide-StateName*)))
     (cond ((or (not msg) (wcmatch (strcase msg) "*EXIT*,*QUIT*,*ABORT*"))))
           (t (prompt (strcat "*** Error: " msg " ***"))))
     (princ))
   (layerstate-save *LayUnHide-StateName* 3 nil)
   (c:LayAllShow)
   (while (setq en (entsel "\nSelect object on layer to unhide: "))
     (setq LayersToTurnOn (cons (cdr (assoc 8 (entget en))) LayersToTurnOn)))
   (*error* nil)
     (if (vl-position (vla-get-Name lay) LayersToTurnOn)
       (progn (vla-put-LayerOn lay :vlax-true) (vla-put-Freeze lay :vlax-false))))
   (princ))
irneb
« Reply #16 on: November 06, 2012, 03:09:12 AM »
Sorry about the typo, thanks Lee for catching it. I'll have to do a bit of testing on this, it seems the parentheses are wrong elsewhere too.
« Reply #17 on: November 06, 2012, 08:15:49 AM »
Replace this :
with this to see it that is where the error is:
      (vl-catch-all-apply '(lambda ()
RolandOrzabal
« Reply #18 on: November 06, 2012, 08:20:44 PM »
still nothing happens...
LayAllShow returns an Invalid Layer Error
irneb
« Reply #19 on: November 07, 2012, 12:24:21 AM »
OK, fixed it ... sorry real stupid mistakes. Comes from trying to program without debugging inside VLIDE.
  1. (defun c:LayAllThaw  ()
  2.     (vl-catch-all-apply 'vla-put-Freeze (list lay :vlax-false)))
  3.   (princ))
  4.
  5. (defun c:LayAllOn  ()
  6.     (vl-catch-all-apply 'vla-put-LayerOn (list lay :vlax-true)))
  7.   (princ))
  8.
  9. (defun c:LayAllShow () (c:LayAllThaw) (c:LayAllOn))
  10.
  11. (setq *LayUnHide-StateName* "_LayerUnHide_")
  12. (defun c:LayUnHide  (/ *error* LayersToTurnOn en)
  13.   (defun *error*  (msg)
  14.     (if (layerstate-has *LayUnHide-StateName*)
  15.       (progn (layerstate-restore *LayUnHide-StateName* nil)
  16.       (layerstate-delete *LayUnHide-StateName*)))
  17.     (cond ((or (not msg) (wcmatch (strcase msg) "*EXIT*,*QUIT*,*ABORT*")))
  18.    (t (prompt (strcat "*** Error: " msg " ***"))))
  19.     (princ))
  20.   (layerstate-save *LayUnHide-StateName* 3 nil)
  21.   (c:LayAllShow)
  22.   (while (setq en (entsel "\nSelect object on layer to unhide: "))
  23.     (setq LayersToTurnOn (cons (cdr (assoc 8 (entget (car en)))) LayersToTurnOn)))
  24.   (*error* nil)
  25.     (if (vl-position (vla-get-Name lay) LayersToTurnOn)
  26.       (progn (vla-put-LayerOn lay :vlax-true) (vla-put-Freeze lay :vlax-false))))
  27.   (princ))
Firstly the cond inside the *error* handler was simply incorrect! 2nd had to add the catch into the All on/thaw defuns. 3rd add a regen after thawing. And lastly car of the entsel  :-[
Edit: [RANT]And WTH? I'm attempting to do this from IE9 today. On the office PC. Now I can fully realize just how much suffering the guys complaining about the forum's code blocks have. It's not just copying the code from the post, it's also issues with pasting the code into the edit box. You keep losing formatting - line feeds and tabs just go crazy! I've never had such issues with FF! ... [/RANT]
« Last Edit: November 07, 2012, 12:50:17 AM by irneb »
RolandOrzabal
« Reply #20 on: November 07, 2012, 12:40:36 AM »
  3.   (princ))
  4.
  7.   (princ))
  8.
  10.
  19.     (princ))
  21.   (c:LayAllShow)
  24.   (*error* nil)
  27.   (princ))
irneb thanks a lot for your effort,
am getting this error
after issuing the command it will show all off/frozen layers,
after picking the layer to turn-on/thaw, this error shows up
Command: layunhide
Regenerating model.
Command:
*** Error: Automation Error. Invalid layer ***
« Last Edit: November 07, 2012, 12:44:07 AM by NOD684 »
irneb
« Reply #21 on: November 07, 2012, 02:31:35 AM »
Replacement for lines 29-31:
  1.     (if (vl-position (vla-get-Name lay) LayersToTurnOn)
  2.       (foreach func '((vla-put-LayerOn . :vlax-true) (vla-put-Freeze . :vlax-false))
  3.  (vl-catch-all-apply (car func) (list lay (cdr func))))))
Again, for some reason certain layers cause errors - perhaps current layer? Or locked? Or defpoints / 0? Anyhow the catch should perform correctly. Also added another regen, otherwise the thaw doesn't display imediately after completing.
Edit: Again! See how screwed up IE's working with the forum editor? Tab indents just go silly!  :realmad:
RolandOrzabal
« Reply #22 on: November 07, 2012, 03:00:24 AM »
irneb...no error this time
LayAllShow shows all frozen/off layers
but after picking the layer to turn on/thaw
nothing happens...it is still OFF/frozen
0 is not my current Layer.
tried it on other drawings but still the same
irneb
« Reply #23 on: November 07, 2012, 03:35:20 AM »
I don't know what to tell you. It seems to work fine here in ACA 2013 (sorry don't have a Vanilla here) ... for a while. Though sometimes I have to do it twice to the same layer before it catches. It's as if the first time round the layer doesn't allow itself to be "shown", but the second time round it says: "Agh alright ... if you want it so much then FINE!!!"  :realmad: Bloody lazy layers  :pissed:
It doesn't happen on all layers, just some of them. I can't figure out why this happens. Nothing locked or any such. It seems to happen on layers which were frozen or off - makes no difference. Anyone know why this occurs?
RolandOrzabal
« Reply #24 on: November 07, 2012, 04:03:20 AM »
don't know too why...am using 2010
on my side even though i select the layers i want to show multiple time..still nothing happens.
I tried it on somebody else's pc and somebody else's file
same problem
irneb
« Reply #25 on: November 07, 2012, 04:16:32 AM »
When I say multiple times, I don't mean pick the layer numerous times. I mean run the LayUnHide command twice, pick the same object again & press enter again. After the 2nd run the layer turns on ... extremely strange!
I even thought it might be due to the Layer Manager Palette (since that sometimes causes these "cannot change layer properties" issues). But turning it off didn't do anything. Unfortunately I can't check if the ribbon has an effect, since there's no "Classic" setup in ACA - no menu bar either! I'm lost on this.
I was thinking of adding a repeat loop to perform the change multiple times, or even testing if the catch failed and repeat until it doesn't. That seems to work:
  3.   (princ))
  4. (defun c:LayAllOn  ()
  5.     (vl-catch-all-apply 'vla-put-LayerOn (list lay :vlax-true)))
  6.   (princ))
  7. (defun c:LayAllShow () (c:LayAllThaw) (c:LayAllOn))
  8. (setq *LayUnHide-StateName* "_LayerUnHide_")
  9. (defun c:LayUnHide  (/ *error* LayersToTurnOn en)
  10.   (defun *error*  (msg)
  11.     (if (layerstate-has *LayUnHide-StateName*)
  12.       (progn (layerstate-restore *LayUnHide-StateName* nil)
  13.       (layerstate-delete *LayUnHide-StateName*)))
  14.     (cond ((or (not msg) (wcmatch (strcase msg) "*EXIT*,*QUIT*,*ABORT*")))
  15.    (t (prompt (strcat "*** Error: " msg " ***"))))
  16.     (princ))
  17.   (layerstate-save *LayUnHide-StateName* 3 nil)
  18.   (c:LayAllShow)
  19.   (while (setq en (entsel "\nSelect object on layer to unhide: "))
  20.     (setq LayersToTurnOn (cons (cdr (assoc 8 (entget (car en)))) LayersToTurnOn)))
  21.   (*error* nil)
  22.     (if (vl-position (vla-get-Name lay) LayersToTurnOn)
  23.       (foreach func '((vla-put-LayerOn . :vlax-true) (vla-put-Freeze . :vlax-false))
  24.  (while (vl-catch-all-error-p (vl-catch-all-apply (car func) (list lay (cdr func))))))))
  25.   (princ))
Though I really don't like the idea of looping until some weird thing stops happening ... or rather not-happening. It's like a cop-out and could lead to an infinite loop.
