Author Topic: Help to Modify a LISP  (Read 5694 times)
RolandOrzabal
  • "memories fade but the scars still linger"
« on: October 31, 2012, 05:02:55 AM »
can somebody help me to modify a lisp i found at cadalyst. This is useful but after issuing the command and the routine thawing the drawing, if the user accidentally hits escape key, it does not revert back to its old state and shows all the frozen layers. Maybe an error tap will solve this but am not that good at that...
here's the code :
;;;                    *** LYR-UNHIDE.LSP ***
;;; This function dynamicaly "TURN ON" frozen layers by selecting objects
;;; lying on these layers. The procedure is achieved by temporary turning
;;; on all layers to enable selection.
;;; "Specially recommanded to use on Xrefs" - Raymond Rizkallah, Aug. 2007
(defun C:LUH (/ entsll laynam laypmt  )
  (setq orgm (getvar "regenmode"))
  (setq laylst nil laypmt " ")
  (command "undo" "m" "undo" "g")
    (setvar "regenmode" 1)
  (command "layer" "t" "*" "on" "*" "")
  (while
    (setq entsll (nentsel "\n Select object on layer to be unhidden: "))
    (setq laynam (cdr (assoc 8 (entget (car entsll)))))
    (if (null laylst) (setq laylst (strcat laynam ",")) (setq laylst (strcat laylst laynam ",")))
    ;(prompt (strcat "\n   <" (substr laylst 1 (1- (strlen laylst))) ">"))
    (setq laypmt (strcat laypmt "<" laynam "> ; "))    (prompt (strcat "\n" laypmt))
  ) ;end while
  ; (command "undo" "end" "undo" "1")
  (if laylst (command "layer" "t" laylst "on" laylst "u" laylst ""))  ;end if
  (setvar "regenmode" orgm)
) ;end function
(prompt "\n Use [C:LUH] to dynamicaly reveal hidden layers. ")
cadplayer
Re: Help to Modify a LISP
« Reply #1 on: October 31, 2012, 07:00:01 AM »
I´m little confuse what you want to do ... is it another to isolate or unisolate layers?
RolandOrzabal
« Reply #2 on: October 31, 2012, 11:10:00 AM »
Hi Cadplayer, just wanted to have a error trap in which when the user hit the escape key, those layers that were temporarily thawed will be frozen/hidden again.
if you try running the program, after issuing the command and hitting the escape key, it does not restore the previous state of the layers.
you will need to run undo command first for it to restore the previous layer states...
is it possible that after you hit escape and the routine stopped, it will automatically restore the layer state and no need for the undo command....
Stefan
« Reply #3 on: October 31, 2012, 12:53:44 PM »
Try this (as an example to fix your routine, or use it if you like it)
  1. (defun C:THAWLAY (/ *error* acDoc layers layer freez_list on_list e)
  2.         layers (vla-get-layers acDoc)
  3.   )
  4.
  5.   (defun *error* (msg)
  6.     (foreach x on_list (vla-put-LayerOn (vla-item layers x) :vlax-true))
  7.     (foreach x freez_list (vla-put-Freeze (vla-item layers x) :vlax-true))
  8.     (vla-regen acDoc acActiveViewport)
  9.     (vla-EndUndoMark acDoc)
  10.   )
  11.
  12.   (vlax-for layer layers
  13.     (if
  14.       (= (vla-get-Freeze layer) :vlax-true)
  15.        (progn
  16.          (vla-put-Freeze layer :vlax-false)
  17.          (setq freez_list (cons (vla-get-Name layer) freez_list))
  18.        )
  19.        (progn
  20.          (vla-put-LayerOn layer :vlax-false)
  21.          (setq on_list (cons (vla-get-Name layer) on_list))
  22.        )
  23.     )
  24.   )
  25.
  26.   (vla-regen acDoc acActiveViewport)
  27.
  28.   (while
  29.     (or
  30.       (setq e (car (nentsel)))
  31.       (and (= (getvar 'errno) 7) (setvar 'errno 0))
  32.     )
  33.      (if e
  34.        (progn
  35.          (setq layer      (cdr (assoc 8 (entget e)))
  36.                freez_list (vl-remove layer freez_list)
  37.                on_list    (cons layer on_list)
  38.          )
  39.          (vla-put-LayerOn (vla-item layers layer) :vlax-false)
  40.        )
  41.      )
  42.   )
  43.
  44.   (*error* nil)
  45.   (princ)
  46. )
RolandOrzabal
« Reply #4 on: October 31, 2012, 09:06:18 PM »
@stefan, what does your routine do? i've tried it and it does nothing...or maybe i've done something wrong....
what the routine does is that it "temporarily" turns on frozen and off layers, then you select which layers you want to turn on/thaw then it reverts back to the previous layer state except for the ones you pick.
the problem is that after you "temporarily" turn on the frozen/off layers and you hit escape, the frozen/off layers are all thawed/on and you need to issue undo command to turn them back to their state.
what i want if possible is that when you hit escape key, it reverts back to its previous state and no need to issue the undo command.
Stefan
« Reply #5 on: November 01, 2012, 06:50:46 AM »
Works only for frozen layers. On error (or hitting escape) will turn on temporary hidden layers, but will keep changes already made.
Stefan
« Reply #6 on: November 01, 2012, 08:26:24 AM »
To answer your fist post, try this
  1. ;;;========================================================================
  2. ;;;                    *** LYR-UNHIDE.LSP ***
  3. ;;;========================================================================
  4. ;;;
  5. ;;; This function dynamicaly "TURN ON" frozen layers by selecting objects
  6. ;;; lying on these layers. The procedure is achieved by temporary turning
  7. ;;; on all layers to enable selection.
  8. ;;;
  9. ;;;
  10. ;;; "Specially recommanded to use on Xrefs" - Raymond Rizkallah, Aug. 2007
  11. ;;;========================================================================
  12.
  13. (defun C:LUH (/ *error* entsll laynam laypmt  )
  14.
  15.   (setq orgm (getvar "regenmode"))
  16.   (setq laylst nil laypmt " ")
  17.   (command "undo" "m")
  18.
  19.   (defun *error* (msg)
  20.     (command "undo" "b")
  21.     )
  22.
  23.     (setvar "regenmode" 1)
  24.   (command "layer" "t" "*" "on" "*" "")
  25.   (while
  26.     (setq entsll (nentsel "\n Select object on layer to be unhidden: "))
  27.     (setq laynam (cdr (assoc 8 (entget (car entsll)))))
  28.     (if (null laylst) (setq laylst (strcat laynam ",")) (setq laylst (strcat laylst laynam ",")))
  29.     ;(prompt (strcat "\n   <" (substr laylst 1 (1- (strlen laylst))) ">"))
  30.
  31.     (setq laypmt (strcat laypmt "<" laynam "> ; "))    (prompt (strcat "\n" laypmt))
  32.
  33.   ) ;end while
  34.
  35.   ; (command "undo" "end" "undo" "1")
  36.   (command "undo" "b")
  37.   (if laylst (command "layer" "t" laylst "on" laylst "u" laylst ""))  ;end if
  38.
  39.   (setvar "regenmode" orgm)
  40.   (princ)
  41.
  42. ) ;end function
  43.
  44. ;;;========================================================================
  45.
  46. (prompt "\n Use [C:LUH] to dynamicaly reveal hidden layers. ")
  47.
RolandOrzabal
« Reply #7 on: November 01, 2012, 08:40:44 PM »
  4. ;;;
  8. ;;;
  9. ;;;
  12.
  14.
  18.
  21.     )
  22.
  25.   (while
  30.
  32.
  33.   ) ;end while
  34.
  38.
  40.   (princ)
  41.
  42. ) ;end function
  43.
  45.
  47.
Thanks a lot! it's just how i wanted it to be....
thanks again stefan
irneb
« Reply #8 on: November 02, 2012, 01:34:27 PM »
Perhaps this:
  1. (defun c:LayAllThaw  ()
  2.     (vla-put-Freeze lay :vlax-false))
  3.   (princ))
  4.
  5. (defun c:LayAllOn  ()
  6.     (vla-put-LayerOn lay :vlax-true))
  7.   (princ))
  8.
  9. (defun c:LayAllShow () (c:LayAllThaw) (c:LayAllOn))
  10.
  11. (setq *LayUnHide-StateName* "*LayerUnHide*")
  12. (defun c:LayUnHide  (/ *error* LayersToTurnOn en)
  13.   (defun *error*  (msg)
  14.     (if (layerstate-has *LayUnHide-StateName*)
  15.       (progn (layerstate-restore *LayUnHide-StateName* nil) (layerstate-delete *LayUnHide-StateName*)))
  16.     (cond ((or (not msg) (wcmatch (strcase msg "EXIT,QUIT,ABORT"))))
  17.           (t (prompt (strcat "*** Error: " msg " ***"))))
  18.     (princ))
  19.   (layerstate-save *LayUnHide-StateName* 3 nil)
  20.   (c:LayAllShow)
  21.   (while (setq en (entsel "\nSelect object on layer to unhide: "))
  22.     (setq LayersToTurnOn (cons (cdr (assoc 8 (entget en))) LayersToTurnOn)))
  23.   (*error* nil)
  24.     (if (vl-position (vla-get-Name lay) LayersToTurnOn)
  25.       (progn (vla-put-LayerOn lay :vlax-true) (vla-put-Freeze lay :vlax-false))))
  26.   (princ))
« Last Edit: November 02, 2012, 01:41:00 PM by irneb »
RolandOrzabal
« Reply #9 on: November 04, 2012, 08:23:47 PM »
irneb; am getting this error :
; error: An error has occurred inside the *error* functiontoo few arguments
« Last Edit: November 07, 2012, 12:44:50 AM by NOD684 »
« Reply #10 on: November 05, 2012, 11:41:50 AM »
After a quick glance, change:
  1. (wcmatch (strcase msg "EXIT,QUIT,ABORT"))
to:
  1. (wcmatch (strcase msg) "*EXIT*,*QUIT*,*ABORT*")
« Reply #11 on: November 05, 2012, 01:10:11 PM »
First test & this fails for me on ACAD 2006.
Can not change the current layer.
(defun c:layallon ()
  (vlax-for lay (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
    (vla-put-layeron lay :vlax-true)
« Reply #12 on: November 05, 2012, 01:18:08 PM »
Where are these routines?
layerstate-has
layerstate-save
« Reply #13 on: November 05, 2012, 01:21:07 PM »
layerstate-has
layerstate-save
Those are part of the layerstate-* AutoLISP functions, but I'm not sure in which version they were introduced:
« Last Edit: November 05, 2012, 01:24:26 PM by Lee Mac »
« Reply #14 on: November 05, 2012, 02:07:39 PM »
Thanks Lee, they don't exist in vanilla 2006.
Perhaps one of those calls withing the error handler is throwing the error.
