Author Topic: Increment Challenge..  (Read 8477 times)
Re: Increment Challenge..
« Reply #30 on: September 13, 2016, 12:54:39 PM »
 :wink:
_$ (ff "a" 25)
"a"
_$ (ff "a" 701)
« Reply #31 on: September 13, 2016, 02:59:11 PM »
I've been reluctant to post in this thread because I don't have time to explain these excerpts from my library.
So I offer them "as is" for idea fodder, noting they were written for other purposes, and are only a small subset of a library of 60 related encoding/encryption/bit packing functions (there's other to/from flavors corresponding to other 2^x boundaries).
Anyway ...
(defun _Map32 ( )
    ;;  © Michael Puckett
    (setq **map32**
        (vl-string->list
            ;;  Note the omission of letters I,L,O,Q
            "0123456789ABCDEFGHJKMNPRSTUVWXYZ"
    (defun _Map32 ( ) **map32**)
    **map32**
(defun _ToMap ( i map )
    (   (lambda ( mask shift / result )
            (while (not (zerop i))
                (setq
                    result (cons (nth (logand mask i) map) result)
                    i      (lsh i shift)
            (vl-list->string result)
        (1- (length map))
        (- (fix (/ (log (length map)) (log 2))))
(defun _FromMap ( x map )
    (   (lambda ( x map shift result )
            (while x
                (setq result (+ result (length (member (car x) map))))
                (if (setq x (cdr x)) (setq result (lsh result shift)))
            result
        (mapcar 'chr (vl-string->list x))
        (mapcar 'chr (reverse (cdr map)))
        0
(defun _To32 ( i )
    (_ToMap i (_Map32))
(defun _From32 ( x )
    (_FromMap x (_Map32))
(defun _Inc32 ( x i )
    (_To32 (+ i (_From32 x)))
The range of values that can be represented by these functions corresponds to the range of integers that AutoCAD can represent:
    (expt 2 31)      >> -2147483648, (_To32 (expt 2 31))      >> "2000000"
    (1- (expt 2 31)) >> +2147483647, (_To32 (1- (expt 2 31))) >> "1ZZZZZZ"
To understand why (expt 2 31) yeilds a negative value the uninitiated may wish to read articles on "two's complement".
Code performs no hand handholding. See _Map32 function for acceptable data, notwithstanding AutoCAD's integer limits. Pass stupid data, crash, get stupid results or an std.
Examples:
    (_Inc32 "0" 1)      >> "1"
    (_Inc32 "0" -1)     >> "3ZZZZZZ"
    (_From32 "3ZZZZZZ") >> -1
    (_Inc32 "0" 31)     >> "Z"
    (_Inc32 "0" 32)     >> "10"
    (_Inc32 "Z" 1)      >> "10"
    (_Inc32 "ZZ" 1)     >> "100"
    (_Inc32 "Z" -1)     >> "Y"
    (_Inc32 "ZZ" -1)    >> "ZY"
    (_Inc32 "ABC" 1)    >> "ABD"
    (_Inc32 "ABC" 10)   >> "ABP"
    (_Inc32 "ABC" 100)  >> "AEG"
    (_Inc32 "ABC" -1)   >> "ABB"
    (_Inc32 "ABC" -10)  >> "AB2"
    (_Inc32 "ABC" -100) >> "A88"
FWIW / Have fun.
Cheers.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #32 on: September 15, 2016, 09:34:18 AM »
FWIW / Have fun.
Cheers.
Thank you!
I've never used LOGAND function with negative numbers...
  1. (logand 31 -1)
« Reply #33 on: September 15, 2016, 10:17:46 AM »
(logand x -1) will always return x because -1 = 1111111111111111. :)
« Reply #34 on: September 15, 2016, 05:51:28 PM »
  1. (logand 31 -1)
FWIW, under such circumstances, I find the use of the bitwise NOT operator easier to understand which bits are being masked - for example, using:
  1. (logand 13 (~ 8))
It is clear that we are returning every bit except 8.
This is equivalently:
  1. (logand 13 -6)
Which isn't so readable with the two's-compliment mental arithmetic.
For the given example:
  1. (logand 13 (~ 0))
i.e. mask nothing, return all.
Thank you for sharing your endeavours MP.
« Last Edit: September 15, 2016, 05:55:36 PM by Lee Mac »
« Reply #35 on: September 15, 2016, 07:19:26 PM »
<nodding> Agree, the bitwise not is useful and often makes clearer one's intent. Thanks LM.
